Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor
Skidsteer job till noon , barn building till 8:30 tonight, all trusses set and almost all pearlings up,with any luck get the tin on and finish it up tomorrow, here are a few pictures
   / Pictures from a skid steer mowing contractor #562
Lineman: is this you? I was traveling on I75 last Sunday. I took this picture between Lake City and Alachua. Just asking..
No sir that's not me.
   / Pictures from a skid steer mowing contractor #564
Are you putting any sides at all on it?
   / Pictures from a skid steer mowing contractor #565
Mr. Lineman, any big snake stories while clearing?
   / Pictures from a skid steer mowing contractor #566
Okay I was in your area ( I think). But it was Sunday. Just thought I'd ask.
   / Pictures from a skid steer mowing contractor #567
4+ feet deep and 240 pounds of sakrete around each post.
That's not going anywhere!!!!
How where those trusses to install? I've thought about using them when I build my shop. Is it just a simple, bolt them together, pick them up and then bolt them into place, type of install?
No I plan on putting a lean to the full length down both sides, just don't wan't to jump on it right now, probably January or February.
Yeah they are pretty simple , just make sure that you get the ones made out of 2x2 angle and not 1&1/2, they can get a little wobbly but the trick is getting the first 2 plumb and get some ratchet straps on them while you set the rest and run your rat runs to tie it together.
Well it took till 8:30 tonight but we finished it this evening and I am glad, it was brutally hot and we all were done in this afternoon, I don't know why I jumped on this in July but I did 😅.
2020 VOLVO VNL SLEEPER (A52576)
2020 VOLVO VNL...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 New/Unused Wolverine Snow Pusher (A51573)
2025 New/Unused...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
