Picture of 3 point hitch
   / Picture of 3 point hitch #1
PA hayseed
Platinum Member
The real central PA
nx5010 hst cab
was mowing and heard a big bang, stopped tractor and mower had run over a part of the 3 point hitch, not the arms, the sway bar? on the left side. I can't find a close up of the left side to see what came off. The right side is fine, but I can't figure out if I just lost a pin or a pin and some other part. Walked all over the field looking for parts, but it would be like the proverbial needle in a hay stack.
DK45sehst.
Any help in locating a picture of this on the left side (looking at it from the rear)? Checked kiotis site but the picture was too small.
   / Picture of 3 point hitch #2
Can you show a pic of the undamaged side?
   / Picture of 3 point hitch #3
Similar thing happened on my DK45S. I think a pin broke or fell out and I lost part of the sway brace. I've found other pins missing so I check now every time I use the machine.
My DK is different from yours but one of these (depending on your s/n) should help.
OEM Parts
OEM Parts
   / Picture of 3 point hitch #4
DK45sehst.
http://www.tractorbynet.com/forums/owning-operating/281300-kioti-hitch-missing-bolt.html
Maybe Same thing happened to me. $15 bolt. Going to put some medium locktite back on it this time.
   / Picture of 3 point hitch #5
Thanks for the post, because it reminds me that mine came loose recently, and I was able just to put back together, but need cotter key to secure it. I have lost a U piece of metal on the swing bar on my CK30. I ordered one, have it ready to go, but, so far, the one I built is working fine.
OEM Parts
OEM Parts
sorry I haven't gotten back here sooner to thank you for your post. Looks like I need several pieces, two pins, a bracket, and a cotter key. How did all that come apart mowing I have no idea. I blame the politicians - heck I figure they had something to do with it. They ruin everything else
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
