dieselfuelonly
I finally bought a trailer.
Its 82" wide, 16' long not including a 2' dovetail, has a metal deck (not one piece of wood on it to rot), pintle hitch, ramps that store under the deck, 8-lug, 16" wheels running standard 235/85/R16 E-rated truck tires that are in good shape, brakes on both axles, etc.
It needs a little wiring work here and there, I think the brake wiring came disconnected on the front axle, and I need to convert it over to the newer 7-pin "RV-Style" connector.
The mechanical thing it needs is I probably need to repack the bearings on the left rear hub, as it was running pretty hot. All of the others were cool to the touch. It looks like the seals may leaking a little bit on the rear axle so I'll probably repack both sides and inspect everything and get it all ready to go. I also need to bang the ramp storage slots back into shape, they are a little bent which lead to one of the ramps being pretty hard to pull out.
I'm not sure how much its rated for, I cannot find any tags on it that state the weight rating. However, I'm sure its a lot, its a really nice trailer.
