Pics of my new (to me) 1700 and some questions
   / Pics of my new (to me) 1700 and some questions #162
Make a spacer for your muffler and use longer bolts. Really not much stress in that area.
   / Pics of my new (to me) 1700 and some questions #163
PC- I knew you would end up all in on the 1700 !!!! The clean-up,muffler and seat look great, I agree soon you will be afraid to get it dirty..........
From CT !!
How would I go about making a spacer? Would it not need a flange on both ends matching the bolt pattern of the current setup? Seems to me it would be easier to just cut the pipe and weld in an extension, no? I guess no matter what I do, it will end up being a "hack job".
Nah, it's plenty dirty right now actually. You might not be able to tell from the pictures, but you can in person if you look closely enough. :D
   / Pics of my new (to me) 1700 and some questions #166
Thick piece of steel, plasma cutter and a drill. I was thinking along the lines of 1/2" or so just to get more clearance to the hood. Getting back the full 2 inches would be a pretty thick spacer. Cutting and welding the pipe would be better for that.
   / Pics of my new (to me) 1700 and some questions #167
Hi Pete,
Just caught the last of the conversation here, where did you get the seat?
Looks great, my old seat looks like your old one.
Thanks,
Mack
   / Pics of my new (to me) 1700 and some questions #168
Hi JC,
I was wondering if you could tell me where to get a manual.
I have a shifter leaking from under the boot and was trying to figure out how to stop it.
Any ideas?
Anyone?
Thanks,
Mack
   / Pics of my new (to me) 1700 and some questions #169
Hi JC,
Any ideas?
Anyone?
Thanks,
Mack
Mack,
what I have is an IT manual , it is FO44 that I bough from TSC I think under $25 many years ago. Augment that with NH website and you'll have 90% of all you need. You need a a new tight booth with fresh rubber. You can buy that from your local NH Dealer. Look at the attachments below that might help you.
JC,
   / Pics of my new (to me) 1700 and some questions #170
  • TRANSMISSION CASE & GEAR SHIFT, 1700 & 1900.pdf
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
2018 Ford F-150 Pickup Truck, VIN # 1FTMF1C54JKF07230 (A57453)
2018 Ford F-150...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
