pics for glowplug
/ pics for glowplug #2
Nice pics there m7040. Now I can finally see what all your nice toys look like. That 4-in-1 bucket is really sweet! I can think of many uses for one of those. I could even use it to come down on fencing and yank it straight out of the ground. That would be too sweet.
One question though, why did you post that thread in John Deere Owning/Operating and link to it from Kubota Owning/Operating??
/ pics for glowplug
that was a mistake so just copied the link rather than redo it. Her are a couple of pics with the ballast box mounted
/ pics for glowplug #4
The way I operate the loader, that box would be on the ground! You may want to think about a way of limiting or eliminating any rearward motion of the box.
jb
/ pics for glowplug
plan to put a chain around it with a load binder strapping it down
/ pics for glowplug #6
Maybe I missed it, but do you know how much that thing, when full, weighs? I like the gray paint and the Kubota logo. Nice touch!
/ pics for glowplug
Keving not sure what it weighs but think about 1500 lbs plus range. I can always add another board and fill it higher if more is need. Will try it out under various situatuations.
/ pics for glowplug #8
If you took a few cubic cm of that sand and weighed it and knew the dimensions of the box it would be very easy to calculate the weight. Probably wouldn't even need the forum engineers; I bet I could even do it!:D If you really wanted to get crazy you could fill it with lead shot. But gotta watch the lead poisoning. Maybe steel shot would be a better idea.
/ pics for glowplug #9
Yuo won't have a problem with your 4 bottom plow as I pull a 3 bottom with my m 5700 with no problem at all.I have to use 4wd at times if the soil is a little wet as I have r4 tires on mine but in 4wd it pulls very nicely.
/ pics for glowplug
Measured the ballast box and found it has 15 cft in it and at 150 lbs per cft that is in excess of 2000 lbs in it for rock sand. It has very good traction as it pushed over a large tree roots and all in one push and without skidding tires at all. See attached pics
/ pics for glowplug
a few pictures of the 4-in-one-bucket in action. It worked very well with rocks digging etc
/ pics for glowplug #12
Do you think the 4n1 is better than a bucket with a grapple? What sold you on the 4n1?
/ pics for glowplug
I have a grapple as well on the regular bucket. The 4-in-one can scrape, backdrag, pick up incidental stuff without changing bucket, can hold more, is stronger for heavy digging such as what i did this weekend with 2000 lbs ballast box. very little wheel slip and full bucket every time with frozen ground
/ pics for glowplug #14
That looks good. Glad to see that you've already scraped the "Bradco" decal off. Shows you've been using it like it's supposed to be.
/ pics for glowplug #15
did you actually pick up the rock? I need to get one of these... How much and where? Sorry if I missed it earlier.
/ pics for glowplug
Keving, it is made by Bradco and is there 73 inch bucket. Sold only by tractor dealers and costs about 2400 dollars. It is made very well and is made to be used hard. The rock was too heavy and estimate it to be 10,000 lbs. Could only push it around.
/ pics for glowplug #17
Probably a good thing. Your grill gaurd wouldn't stand a chance against that monster!
Nice rig.
/ pics for glowplug #18
Thanks for the info. It's amazing what you can push around with this thing.
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
2014 Freightliner Bucket Truck (A63689)
3147 (A63117)
3147 (A63117)
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
