pickup hitch problem
   / pickup hitch problem #1
rusty tractors
johndeere 2140
Hi i have a 2140 4WD and the pickup hitch bolts keep slackening off. and now one of the bolts well not tighten up i have put new bolts and washers in with lock tight i have even put fresh paint in them has any one else had the same problems they still keep coming loose thanks.
   / pickup hitch problem #2
pickup hitch?
is that like the 3pt lift arms?
based on what you describe i have NO idea what bolts you would be talking about.
Perhaps some pics?
FYI as it seems to be a question about your John Deere, the JD guys over in the JD forum might have a better idea.
and welcome to the forums.
   / pickup hitch problem #3
Welcome!
And, I can't figure out what bolts you are talking about, either... agree, need photo...then am sure you'll get good advice...you have done the typical things, so we need more information.
   / pickup hitch problem #4
I am with the others. I have no idea what you are talking about.
Chris
   / pickup hitch problem #5
Welcome .....Pics are your friend and ours too need pics
   / pickup hitch problem #7
Maybe this is a pick-up hitch?
The problem might be it's too high.
Hopefully OP has problem solved by now. :rolleyes:
   / pickup hitch problem #8
It sounds like he has a stripped thread in a casting, if it was a nut and bolt application replacing both would solve it. Unfortunately, locktite and paint are no substitute for threads, and the only solution will be to punch it out to the next oversize, or helicoil it if size is critical.
   / pickup hitch problem #9
5 year old post and the OP only made one post, so I'm guessing we will never know what he was talking about.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
24in Tractor Backhoe Bucket BT4555 (A52748)
24in Tractor...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
