Pickup Checklist
   / Pickup Checklist #1
c5er
Going to pickup the new BX2360 w/ FEL and Snowblower.
Does anyone have a checklist of things i should look for on at pickup time?
   / Pickup Checklist #2
1. Hour meter
2. Do the tires all match
3. Fluid levels
4. Check closely for any rust or paint damage/deteoriation.
5. Lights working properly.
6. Make sure you pay close attention to the delivery instructions.
When you get home READ YOUR MANUAL, highlighter might be helpful.
All I can think of off hand, but will be thinking about it.
   / Pickup Checklist #3
Oh, check for leaks.
   / Pickup Checklist #4
When you recieve your new Kubota there is a pre-delievery inspection sheet.
This will require your signature if your happy.
   / Pickup Checklist #5
Look it over like you plan on keeping it. If there's rust on it, if there's a scratch on it, if the color is off and you don't like it please don't accept it and then come whining to the forum how the seller did you wrong.
Many of us put up with a nick here or there, some faded paint, etc. Others complain if a fly leaves tracks in the wax.
Make sure it works to your expectations.
Check the fluids with the attachments at different levels. It makes a BIG difference. See this thread: http://www.tractorbynet.com/forums/kubota-owning-operating/147705-hydraulic-level.html
   / Pickup Checklist #6
In my opinion, this needs to be added to each model's manual: Re-check front axle fluid after a few hours of operation. It should be a daily check but I think most owners don't check it each use.
The front axle fluid probably won't be fully settled in the axle housings on delivery. Mine, along with many others, was about 1 quart low of SUDT when I checked at 5 hours.
   / Pickup Checklist #7
about the only other thing to add is if you are not familiar with the model, have them show you how all things work and the location of things you need to check regularly. Manuals will show you this but sometimes the drawings are not as easy to picture as opposed to having seen it.
   / Pickup Checklist #8
Ahhh! You'll get so excited you'll forget anything we'd tell you anyway! ENJOY!
2015 Ford F550 Altec Bucket Truck (A52377)
2015 Ford F550...
Skid steer auger plate (A50322)
Skid steer auger...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Towable Diesel Tank (A53421)
Towable Diesel...
