Picking up a CK35 HST soon
   / Picking up a CK35 HST soon #1
saasmc
I will be picking up a CK35 HST soon and was wondering about which rotary cutter to purchase. 5 ft or 6ft? standard or medium. Any suggestions? I will be cutting mostly fields with lite brush.
Steve
   / Picking up a CK35 HST soon #2
They usually say 5 pto hp per ft. is a good combination. I prefer the med. duty even for light work as they should last longer . You want your cutter to be at least as wide as your tire tracks , more is better . If your brush is light you should be able to get by with a little less than the 5 pto hp per ft. if need be .
Thanks, I think I will stick with a 5 ft then and go with the medium. Cannot wait to start playing.
   / Picking up a CK35 HST soon #4
Steve
If you are cutting lite brush I would go with a standard duty cutter.Maybe bush hog or woods brand cutters.
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
