Picked-up Free Murray!
   / Picked-up Free Murray! #1
shortlid
Derry, NH
OK, well I went this weekend and picked-up from my neighbors a FREE '96 Murray Lawn tractor. It has a 6 speed shift on the fly, two blade deck and a I/C B&S, 12 hp single L-head. Only one issue, the starter turns over the engine real slow even when jumped or on new battery?:confused: Cables and wires LOOK OK. Is this a starter or silinoid problem?:rolleyes:
   / Picked-up Free Murray! #2
:D My Murray does the same thing but it still starts. You could test the starter by using a jumper cable to power it directly from the battery for a moment.
Maybe the B&S hads bad starters
Unfortunatly mine cranks too slow to start at this point! It almost gets there but will not fire up.:mad:
   / Picked-up Free Murray! #5
On the Briggs starters I have heard of checking the brush pack in the bottom, sometimes it will need to be replaced other than that check the solenoid, wires and ground
David Kb7uns
   / Picked-up Free Murray! #6
Shorty Howdy, You will be looking quite awhile for solenoid on this mower since they don't have one...If you want to go through the trouble of isolating the wiring issue, take the battery up to the starter and use a good set of jumpers and touch the positive side directly to the starter terminal and battery ground to mower frame if it spins good there you have bad wiring most likely a bad ground...
If it spins slow like before the starter is worn out...:(
Good Luck....:)
BTW sounds like the right price!!
Well the positive leads seem to go througha ingnition switch under the seat on this Murray. Can a autoparts store test this?
Geting jumpers directly to starter, can I use the battery in my truck to start it with teh engine off??
   / Picked-up Free Murray! #9
The easiest way to check wiring is with a good 12v test light. You can be sure that power goes to the (I call it a solenoid) probably under the seat, if there is one, turn the key, and you'll be able to tell if it goes to the other side.
I'm sure you'll get better info from others.
OK so just jump the terminals on the starter SWITCH.
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
1995 GMC CHIPPER/BUCKET TRUCK (A54607)
1995 GMC...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
