Picked up a new (used) disk this weekend...
   / Picked up a new (used) disk this weekend... #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
Paid $175 for the PM brand. Looks about like a lot of other light duty 5' disks. The had just replaced the front disks with some cutters, very sharp still. I got it home and promptly took it apart. I can move it around easier in pieces. Got some bent 3pt stuff straightened. Painted and greased. Interesing there are no bearings, just sort of a heavy grease between the cast housing the the steel shaft. Also had some flywheel on top of it, VERY heavy. May of may not need this if my L will pull it. Now I'm done and I just have to wait to get it up to the country.
So far I think I got a good deal. :)
   / Picked up a new (used) disk this weekend... #2
You did a nice job! Looks great!
   / Picked up a new (used) disk this weekend... #3
Mind if I ask why you decided on black to paint it? Or was it "black is as good as any color" sort of thing?
Im in the "process" of working on a set I got..very similiar to yours but I notice my "trailing arms" ( from the top link connection) on mine go almost all the way to the very back...right about the rear set of discs..? Just another variation I suppose??
Im thinking Kubota Orange...but that might get to be a real PITA..and may decide "black is good enough"...:) But Ive got to get a set of standard sized impact sockets....some of the bolts are just WAYYY to tight for "armstrong" removal.
Local TSC has some pretty decent paint..and if you use their recommended thinner drys FAST...with with their hardener in it...2 coats makes for a pretty DA**ED durable finish....I just have to decide which color is all
I guess it's just a little design difference. I was at the local tractor place on Saturday with my BIL and they basically the same model 4' wide(this one is 5'). $540!!!!!!! Mine has a PM Manufactoring sticker on it, not much on it on the net but the "bearingless" hangers were also on the new $540 version, so I can get parts if I ever need them.
I paint my stuff black because of a study the Houston Fire Department did years and years ago. They use to have red trucks, then painted them white because they would be more visible. After some years they noticed the trucks were rusting at a hight rate (keep in mind they wash the trucks a lot). The study concluded that the darker color held the heat, evaporated the water faster which led to less rust. The white reflected the heat. So since most of my stuff sits outside it makes sense. So everything gets black, also easy to get black to match. Plus that true Kubota orange is very expensive. I also don't like to use spray cans because it's thinned so much you barely get a thick film of paint(and it costs a lot!!) So that's my black story. This disk was yellow, but even after an hour of use this weekend...the color didn't really matter. :) :)
Rob
BTW it did take me some time to fiddle with the lift to get it to cut right. Lift arms had to be set right, then the top link so it would ride flat. But in the end all was well.
   / Picked up a new (used) disk this weekend... #5
Rob
Interesting about the color VS heat..etc...Hmmm??
TSC here has all 25 colors for $23 a gallon...and since I want to do touchup on the FEL bucket this winter ( fall actually) I may just spring for that color.??..who knows at this point..*S*
I know what you mean about "adjustments"..lift arms..top link..etc..etc.
I do understand also about the "price" of new ones!..GEEZE!! The guy I got mine from..a buddy of a buddy kind of thing..was going to GIVE ME this set!!!! and I told him I wasnt having any part of that BS...lol So he says ..How about $150"...and he tossed in a new "TSC" ( china) top link in the deal???...geeeeze! Mighty tough to beat for sure.
Ive already got a spray gun to paint with...but need to get to Harbor Freight tomorrow for some impact sockets. The more I look at it..the more I THINK I want to tear it all down to get everything "scrubbed"..."de-rusted"..lol They sure are worth the effort though...prices of a new set is out of thi world
This one was very easy to tear down. 4 - 1/2" bolts hold on the disk pods (4 total pods). Then the same 1/2" bolts (2 each) hold the "quasai bearing". Instead of using another trailer to haul it up to the country I kept it apart, laid the fram in the back of my pick up, rolled the atv on top and loaded the pods along sode of the atv. Then put the frame on the tractor, adjusted the height and bolted the pods on.
Does yours have the quasai type bearings or real bearings. At the tractor place all the small ones had these types. The bigger disks had the sealed bearings.
Check this out, it is a solid steel weight that was on the disk. Got to be 250# or better. I can just lift it off the gound and no way possible can I lift it into a pickup or on the disk. I used ramps to load and unload (actually I dumped it off the bed of my pick up. :) It would probably make it dig better!
Rob
   / Picked up a new (used) disk this weekend... #7
Rob
My "bearing hangers" are different than yours...but it appears the same number of bolts holds mine also. Bearings are like yours ( I saw the opened up one..)..and frankly..the more I understand about them..I prefer the type we have. Ive NEVER seen any "sealed bearing" that at some point didnt go bad...because of lack of lubrication.....and how can one ADD lube to a "sealed" bearing? Of course if we dont put new lube in ours from time to time..they will go south also...
Not sure what I'll use for additional weight on it...if and when I thin I might need some??
I'll probably wind up twisting all my hanger bolts off using an impact wrench ( no torch here...*pout*)...I tried breaking them loose with a socket and 24" breaker bar and thought I was going to rupture myself...:) MANNNN are they TIGHT...but I have to get them off so I can turn it upside down to scrape ; wirebrush and prime the underside of the frame. Im going to pick up new lift pins too...might as well...:)
Its running in the mid 90's here this week...so "outside work" is a bare minimum...:)...but I'll try and take a few snap pics of what I have and show you this setup.
   / Picked up a new (used) disk this weekend... #8
Here's some quick snaps I took...showing the different bearing hangers and the toplink struts. MAN I wish it was in the 60's here so I could get something really done on this thing!!
Interesting, same disk pods though. Notice it's a simpler design. Only one piece of bent angle in the whole thing, mine has 4. This would be easier to copy as a home made disk if someone could round up the other parts. Is the smooth round sleeve between disks 2-3 hollow or is that covering something. If you look at the pic below you can see on mine the sleeve or separator can actually be swapped out to one of the greased ends. But if you look closer at the one in the pic it looks like its already been used and looks worn. I remember a couple of mine have not been use.
Nice pics and let me know how id digs. We really have the same set up.
Thanks,
Rob
   / Picked up a new (used) disk this weekend... #10
Thanks,
Rob
No idea about the sleevs...although there is NO bearings inside of it. May NEVER know..because I dont want to have to take anymore apart that I absolutely have to. I wont even remove the bearing housing from the hangers...I know they are full of grease..and turned easily by hand even before I used 2 tubes of grease on this critter. I cant tell from topside is it has BOLTS or STUDS..and I sure as heck dont want to be breaking some studs off and have to go thru that PITA!!!
I went and bought sockets today..up to 1 1/4"..and woudnt you know it..the lift pin nuts are bigger than that!!! Got one off with a pipe wrench...the second..well..all I know is I'll never father any children because of it..LOL. Its getting "La Torch" come friday morning..lol
Got paint..with hardner for it..and PLENTY of thinner for cleanup. BLACK for the disc...:)...and also a qt of Kubota orange for touchup on my FEL later this year.
So far..paint and all..Im in hock for close to $200.. ( and 3 buckets of dammed sweat...:)..) still aint a bad deal though.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
