PIcked up a 3165 this weekend.
   / PIcked up a 3165 this weekend. #1
Morkai
Tifton, GA
'05 Cub Cadet GT2544, HDS3165, HDS3225
New edition to my Cub family... I came across a deal on an old 3165 project and couldn't pass it up. It had a stater failure and sat up for a couple years. It was supposedly mowing and working fine before the starter failure and the kid working on it for the owner couldn't get the starter off and he just parked it. It ended up in the hands of a repair guy that's now retiring and wanted to get rid of it for $350. The engine turns, oil looks good, hydro fluid is clean. It's mostly just dirty and a little rust etc from sitting under a shelter for years. It had just had a new gas tank, clean as a new one on the inside. If the hour meter is right it's just over 500hrs.
I guess my first task is to get the starter replaced try to get it to fire up. If the engine cranks and runs good and the hydros are good, I'm going to be a happy camper.
   / PIcked up a 3165 this weekend. #2
Before you buy a new starter, test the old one. I came across a "starter failure" which was really a wiring and switch failure. Much less expensive fix.
jack vines
   / PIcked up a 3165 this weekend. #3
great deal for a 3000 series! Which deck?
The guy had another starter, so all I have to do is swap them. The problem is the top starter bolt. B&S makes a special 1/4" drive universal socket to get at it. Looks like I'm going to have to engineer my own. (I'm not paying $40-50) It's the 54" deck.
Also noticed it has a 51-4 battery, is that the standard in the older machines?
Well, good news and bad news...
I got the starter off, and I don't think there's anything wrong with it. The bad news is the lower bolt hole is broken out on the back side of the block.
Well, the starter mount is FUBAR, but I managed to get it started. After hooking the fuel pump up the right way and cleaning the carb and bypassing the fuel solenoid. Runs pretty good. Everything seems to work, even the low fuel light.
Well, finally got everything up and running and even cut some grass with it this weekend.
19104 (A51694)
19104 (A51694)
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
