Pick up hitch?
   / Pick up hitch? #1
guyd
Bronze Member
I have a 1510 - and I need a decent capacity pick up hitch - not the three point mounted version - anyone seen / made one?
   / Pick up hitch? #2
OK, I admit, I don't know what you are talking about. Any pictures of anything like your asking about or a little more info for someone slow like me?:confused:
   / Pick up hitch?
Its the parrots beak affair under the pto shaft - this lifts up and down (shown in 'up') using the 3ph arms
for towing trailers with ring type hitch - a bit like the NATO standard. How do the colonials tow trailers (non domestic - ie not 50mm/2" ball)?
   / Pick up hitch? #4
I have a 1510 - and I need a decent capacity pick up hitch - not the three point mounted version - anyone seen ... one?
I've been reading this site since 2003 and your photo is the first time I ever saw or heard of one.
Where is this common?
   / Pick up hitch? #5
Thanks for posting the picture. I looked at that sight which is in Ireland. If I wanted something like that I would probably buy the pintle part and then "rig" up some way to mount and swivel it attached to the tractor hitch. That is not any good info to help you but I'm doubting you are going to find a factory job for a 1510 Yanmar. More curiosity, do you move trailers around?
   / Pick up hitch? #6
I don't believe we have anything like that here in the colonies;).
   / Pick up hitch?
wow... dont you? virtually every big tractor here has them - its essential for picking up a ring hitch trailer -
just back tactor up to hitch, lower hook thing, back under ring, raise hook, drive off. Maybe its a design feature created by having a wet country ;) that meant we dont like getting out of the cab.
heres a vid of it working
http://www.youtube.com/watch?v=6KBd0mzjfDo
so how to the damned collonials pick up a trailer then?
occasionally - I have lifted a two + tonne trailer filled with horse manure with my little 1510 - bu twrappign a chain around the top end of the lift arms, and down to the ring - but it was a bit scary, as the trailer was 'penduluming' (is that a word?) on the chain, slamming into the back of the tractor (well, the bit of lift framework on the 3ph). Not fun - but it was only for 1/2 a mile, off road.
   / Pick up hitch? #9
Guyd, never to old to learn something new. No doubt that would be a fine thing to have moving those trailers. Thanks for the vidio. What parts are you from?
   / Pick up hitch?
south west UK - a small area called Exmoor... an hours drive to a decent size town.
edit - heres where i suffer having to live. My house is under the right branch that droops down a bit
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
