Pick Up Hitch / Drawbar - MF 135
   / Pick Up Hitch / Drawbar - MF 135 #1
1968 MF135
Spalding, Lincolnshire
MF135 1968
My MF 135 seems to have a Ferguson TE20 pick up hitch fitted as per the item photo attached.
I need to fit a drawbar to pull a baler - what would you suggest I get / do to convert to allow drawbar use? or can I convert the baler to work on the pickup hitch hook?
Many Thanks
Ok I think I have decided to fit a Towing Eye to the Baler and connect using the pick up hook - anyone see any problems with this?
   / Pick Up Hitch / Drawbar - MF 135 #3
Watch the towing eye length if different to the current tongue length, you may over extend your pto shaft.
Why don't you just get a standard drawbar from a wrecker? Get the 2 pins(2 different lengths) that got with it as well. Fitting is easy, you slide the whole unit(frame and drawbar) under the tractor and lift the back by the end of the drawbar and slid the long pin into the upper holes, then lightly push down on the drawbar to raise the front into the front holes and slid in the short front pin. Then remove the rear pin and raise the rear to the highest setting (drawbar will be level) and refit long pin. Make sure you insert the lynch pin from the front to back(in long and short carrier pin) as long grass can open and remove the lynch pin when inserted from the rear.
There is a "long" and "short" setting for the drawbar length. Try both to see which length the baler runs best on.
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2004 Kubota L4630 (A50123)
2004 Kubota L4630...
Kubota Salt-Spreader (A52384)
Kubota...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
