Loader Pic of bucket leveling bar for DK40SE
   / Pic of bucket leveling bar for DK40SE #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
Mine came loose and got bent. I was wanting to see an unbent one so I can figure out how to reshape mine.
Thanks
   / Pic of bucket leveling bar for DK40SE #2
Mine came loose within the first couple of days it wasn't bent so I just slipped it back in and hand tightened it.
Naturally I forgot to tighten it with a wrench so a few days later I bent it pretty good. I was able to put the end of the bar into the bottom half of the coupling and slowly bend it until it lined up to thread on. Oh yeah this time I was sure to put a wrench to it
   / Pic of bucket leveling bar for DK40SE #3
Here you go.
Perfect. Thanks!
   / Pic of bucket leveling bar for DK40SE #5
By the way that is not my tractor. :) But it looks the same. What I did after mine came loose and I wadded up the rod, I straightened the rod out and reassembled with some blue Locktite, and for insurance I staked the nuts with an automatic center punch.
Yeah I plan on some Locktite also!
   / Pic of bucket leveling bar for DK40SE #7
Good idea on the Locktite.
Mine came loose a couple of years ago. I straightened and reinstalled it, but did not use Locktite. This winter I noticed it missing after blowing snow. I retraced the complete paths a few times without finding it. I figured it would show up this spring when the snow was gone. But no luck--it has disappeared. So now I'm without the rod. I believe a replacement is $56, so I'll get by without it for now. If I replace it I'll make my own by bending and threading some plain rod.
If I do replace it I certainly will use Locktite.
   / Pic of bucket leveling bar for DK40SE #8
Speaking of coming loose just finished putting up my first little bit of hay, the DK45 worked fine on the NH 467 haybine and NH 269 baler, but a 10mm retaining bolt came out of the bottom left 3 pt arm and I lost the pin. Thoughts of a $50 + Kioti part crossed my mind but luckily spotted the pin on the road the next day. So $1.50 bolt and some locktite will fix it.
   / Pic of bucket leveling bar for DK40SE #9
I have found a couple of those pin retaining bolts loose on my loader. I found them in time and retightened them.
I am surprised how the bolts can work loose despite having lock washers. Because of this thread's reminder I will reinstall all them with blue Locktite.
   / Pic of bucket leveling bar for DK40SE #10
We have found some loader bolts are too short also.
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2007 Volvo VNL Truck Tractor (A52748)
2007 Volvo VNL...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
