philisophical question
   / philisophical question #1
NW PA
1941 John Deere B electric start
you go to a Mahindra dealer and there are about 10-15 shiny new Mahindras sitting there. over in the corner, you spot a smaller, late 1950s Oliver in decent shape for its age. which do you buy? :confused:
this is the exact scenario at a local Mahindra dealer and I am curious how others feel.
   / philisophical question #2
Are you looking for a parade tractor or a work tractor?
I'm not personally looking for anything at the moment, I restore tractors to parade condition, but only tractors that can do work when they're restored ;)
   / philisophical question #4
The Oliver will probably be running long after the Mahindras have been melted down and made into something else so...
   / philisophical question #5
Just joking. I've spent a few hours on Oliver 1600 and 1800, and Oliver 70. They probably will last forever doing the field work they were intended for. But field work isn't what a lot of tractors get used for now. I would miss the four-wheel drive, the nice loaders and so forth. I guess it really depends on what you want to use it for.
   / philisophical question #6
I second that opinion:thumbsup:
When I was looking for a tractor, I found a '59 Fordson Power Major that had been sitting for over 9 years in a barn. Put a new battery in it, fresh diesel, checked the oil levels and turned it over. It took some time because I didn't bleed the fuel lines first but it started right up. Smoked a bit at first but it's been a worker ever since. I have more tractor, le$$ into it and I would do it all over again.
   / philisophical question #7
Like Dave said field work isn't what I use tractors for now in general. I would bet the older Oliver with a little work would do everything it could ever do and do it for many more years. If I were to buy the Oliver it would be with disposable income and be for personal enjoyment because I don't need it. The Mahindra I would pass on because this would be a present day tractor to make a living with and there is no dealer support in my locale.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
