philisophical question
/ philisophical question #1
NW PA
1941 John Deere B electric start
you go to a Mahindra dealer and there are about 10-15 shiny new Mahindras sitting there. over in the corner, you spot a smaller, late 1950s Oliver in decent shape for its age. which do you buy? :confused:
this is the exact scenario at a local Mahindra dealer and I am curious how others feel.
/ philisophical question #2
Are you looking for a parade tractor or a work tractor?
I'm not personally looking for anything at the moment, I restore tractors to parade condition, but only tractors that can do work when they're restored ;)
/ philisophical question #4
The Oliver will probably be running long after the Mahindras have been melted down and made into something else so...
/ philisophical question #5
Just joking. I've spent a few hours on Oliver 1600 and 1800, and Oliver 70. They probably will last forever doing the field work they were intended for. But field work isn't what a lot of tractors get used for now. I would miss the four-wheel drive, the nice loaders and so forth. I guess it really depends on what you want to use it for.
/ philisophical question #6
I second that opinion:thumbsup:
When I was looking for a tractor, I found a '59 Fordson Power Major that had been sitting for over 9 years in a barn. Put a new battery in it, fresh diesel, checked the oil levels and turned it over. It took some time because I didn't bleed the fuel lines first but it started right up. Smoked a bit at first but it's been a worker ever since. I have more tractor, le$$ into it and I would do it all over again.
/ philisophical question #7
Like Dave said field work isn't what I use tractors for now in general. I would bet the older Oliver with a little work would do everything it could ever do and do it for many more years. If I were to buy the Oliver it would be with disposable income and be for personal enjoyment because I don't need it. The Mahindra I would pass on because this would be a present day tractor to make a living with and there is no dealer support in my locale.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
1761 (A58375)
1761 (A58375)
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
