PHD PTO shaft too short
   / PHD PTO shaft too short #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I got PHD Leinbach 7400 for my B7800. No matter how I mount it PTO shaft is about 16" short... /forums/images/graemlins/confused.gif How is that possible? Anybody has any ideas?
Alex
   / PHD PTO shaft too short #2
Is it a telescoping shaft that is rusted together? or is it simply way too short a shaft for your mower / tractor combo.. and the shaft comes apart.. as you mention.. 16" apart..
Soundguy
   / PHD PTO shaft too short #3
Post a picture, it is a lot easier to give you an answer if we can see the problem. 16" is a long way off, maybe they gave you the wrong shaft with the PHD. Do you have a quick connect on the 3PH? That would set you back but not 16". I have a PHD and I have a Freedom hitch quick attach and I have moved the PHD through all its mounting points and never came close to running out of shaft.
   / PHD PTO shaft too short #4
I have to second what Soundguy says. I just recently got the leinbach 7400jr for my bx. Try to get the shaft to extend by pulling apart while tapping on it with a rubber mallet.
Thanks for your replys. Can't take a picture. How do I know if it's a telescoping shaft or not?
Alex
   / PHD PTO shaft too short #6
Here is a pic of one in use with the telescopic pto shaft.
I would bet your is telescopic, but maybe just a little stuck..
   / PHD PTO shaft too short #7
Alex,
They are ALL telescopic.
   / PHD PTO shaft too short #8
Yep, They all are telescopping so that it will adjust when you raise or lower the 3ph.
   / PHD PTO shaft too short #9
It has a two piece shaft. A large shaft that slides over a smaller shaft. But it is hidden under the protective plastic cover. It it has set out in the weather it is probably stuck. Mine does. As mentioned, you may to persuade it a little with a rubber mallet or block of wood. Something that will not damage it.
   / PHD PTO shaft too short #10
Found this picture on the Internet, part 5 slides inside of part 6. Hope this helps.
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
Caterpillar 345D Hydraulic Excavator (A50322)
Caterpillar 345D...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
