Haven't checked, what is quick? 3-5 minutes How hot is too hot?
In 3 - 5 minutes with the motor stalled you should be able to feel a definite temperature difference from inlet line to the outlet line if the motor is bypassing.
Not with PHD, but definitely with grapple digging roots/stumps.
Does the grapple run off the same connections as the PHD? If yes this points towards a problem with the PHD
I've got new filters on the way, but leaning towards bypass on the motor. With no load, PHD spins in both directions. Under load, it starts to drill then stalls like it's hitting a root or rock. When I check the hole, nothing to be found :shrug:
