PHD gearbox repair or replace?
/ PHD gearbox repair or replace? #1
Irod
N/a
N/a
I bought a used subcompact post hole digger for $150 from Tractor Supply that supposedly needed a new oil seal. When I took it apart I found the top bearing destroyed. Did they forget to install a cup in the top cover for the bearing? The second image shows the damage to the inside of top cover The lower bearing was intact but really loose but the cup looks okay. Is it worth repairing or just buy a new gearbox? It is a SpeeCo digger with Omni Gear phd-46 gearbox.
/ PHD gearbox repair or replace? #2
If the gears are ok it could be fixed by putting a bushing in the cover to hold a new bearing cup. If you don't have a lathe you'll have to get an estimate from a machine shop and compare to the cost of a new gearbox. Those are things I don't know.
New Holland T5070 (A64126)
New Holland T5070...
1996 Anderson 24' Tilt Trailer (A64126)
1996 Anderson 24'...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
Bale Ring (A66408)
Bale Ring (A66408)
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
