PHD for bx 2230
/ PHD for bx 2230 #1
TrailHermit
Va
Kubota BX 2230
I am thinking of getting a PHD to use with my 2230. I've looked at some past threads on implements and for some of the woods models listed don't see them on their site -- maybe they are older and no longer sold new. The woods PHD25 seems like a good choice -- has anyone had bad experiences with this model?
I will be putting in a 3 board fence and also trees as a natural boundary. Any recommendations on an auger for doing both jobs, or is it better to get different augers?
thanks for your input
/ PHD for bx 2230 #2
Welcome to the forum. (If you fill out your profile, people closer to you and / or familiar with your style of ground can assist you better).
I have a Vassar PHD for my 2200. Works fine. I usually run it just above idle. I think the size of your auger would depend on your ground condition and what size posts you are putting in. Mine is 9" as I put in 4x4 posts. If I go to smaller, metal posts, a 6" would be nice............
As I've posted here previously, I don't like running the PHD--too hard to see what's going on as the unit is close to the tractor. AND, with the 3PH lever on one side and the PTO shutoff on the other, you almost have to be a circus performer to accomplish the turn, turn, turn, look, pull, turn, turn, pull maneauver.
What I've found works best for us is I have my son or wife stand to the right of the tractor, while I stand to the left. He/She operates the 3PH at my command and I handle the PTO. Each of us can see well and the rule is NO ONE GOES PAST THE REAR WHEEL while the PTO is engaged.
Hope this helps.
ron
/ PHD for bx 2230
Ron, thanks for the advice. Which Vassar do you have; the Estate model? Any particular reason why you decided to go with Vassar over other brands?
/ PHD for bx 2230 #5
I have the Woods PHD that works great in all soils exept really rocky plots. Just keep plenty of 4" x 5/16" regular grade shear pin screws in stock because you will snap them. They're easy enough to replace in about 2-3 minutes.
When you hear a large rock scraping immediatly raise the auger and get out a digging bar to dislodge it from the hole manually. Also setting the 3 point hitch lowering speed control to it very slowest drop helps save the shear pins. Since most of the smaller PHD's are made in China, price is what made my choice.
/ PHD for bx 2230 #6
<font color="brown"> I am thinking of getting a PHD to use with my 2230. </font>
I would recommend a PhD in agriculture or horticulture! /forums/images/graemlins/wink.gif
Welcome to TBN!! Steve
/ PHD for bx 2230 #7
You might want to consider the Worksaver since a little birdie has mentioned that the PHD25 from the Woods Estate series is made by Worksaver.
/ PHD for bx 2230 #8
I have a leinbach 7200jr for my bx. Just finished putting 85 holes in the ground for trees. I would recommend the unit. I can post some pics of it digging if needed.
/ PHD for bx 2230
Thanks SCB. If you have time to post a few that would be great. So far I really like the price of the leinbach. Not sure how quality compares to the woods models but they sure are a bit more pricey. I appreciate your recommendation.
/ PHD for bx 2230 #10
Here you go. the first few pictures are of the PHD. the rest are progress pictures to share with my freinds. They do pertain to the BX though, as it shows the progress I have made using it. I did all the clearing and prep work for the grass and driveway with it. Along with many other projects. below my signiature are some links to pictures of what we have accomplished with out BX23. Hope they help. /forums/images/graemlins/grin.gif PHD and hedge planting
/ PHD for bx 2230 #11
Looks good!
What's the maximum depth the 7200jr can dig? Did you get it through Northern Tools?
/ PHD for bx 2230 #12
I beleive it will go 42 inches. I got it through e-bay. There is a company running autions regulary there.
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
Sakai SW354 (A60462)
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
