PETROGEN - gasoline/oxy cutting system
   / PETROGEN - gasoline/oxy cutting system #31
Hi Guys ,, Info for anyone interested from a petrogen user .. I picked up a unit through online auction real cheap (aus$200) .. After the learning stage and finally cleaning out the fuel lines it is great .. The main use is for heating or cutting..( I also have a Diesel/compressed air torch for heavy heating ).Cutting is quick and clean .. Brazing can be done and it seems that brazing with copper wire is easier than using bronze rod .. soldering is easy with it as you can adjust to a broad flame ,just did a tractor radiator top tank fix up ,easiest fix I've done compared to using irons or O/A .. Silver soldering is OK with it .. Used it to place tungsten tiles .. As for fusion welding it will not work as it is highly oxidizing ,,I've got migs and stick welders for that .. Cutting is strange as it is much better on thicker steel than thin section, seems to lose heat from cutting to fast. On one inck and above its like a hot knife through butter .. another bonus is the ability to transport and use straight away. No need to allow acety/acetone to settle. But as already stated if you had to pay full cost you would need a lot of use for it to be viable
   / PETROGEN - gasoline/oxy cutting system #32
I have both propane and Ace the ace seems to start the cut faster and I think I can cut at a faster rate. I am switching back and forth. So far the propane gives a cleaner cut and costs much less. I may not be mixing the propane and oxygen correctly or maybe I hold the flame to close for the start. I own my tanks so I will probably always keep the Ace. Just my 2 cents
   / PETROGEN - gasoline/oxy cutting system #33
We have both the Petrogen torch and the Slice Pack. We term the Slice Pack the "Man Sparkler"
202479 (A54757)
202479 (A54757)
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
FUEL CELL (A58214)
FUEL CELL (A58214)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
