PETROGEN - gasoline/oxy cutting system
   / PETROGEN - gasoline/oxy cutting system #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
   / PETROGEN - gasoline/oxy cutting system #2
Do you own one of these?
Not yet, but it is on my must have list. I have the motorized cutting torch, that will follow a track, or a straight edge.
   / PETROGEN - gasoline/oxy cutting system #4
I can see why you must have one I am at the cutting charistics, cutting through rod that thick and the multiple plate even with an air gap is enough to make any professional smile(by the way I am not a pro welder). I am just glad to have the o/a for what I do but man that is head and shoulders above o/a.
   / PETROGEN - gasoline/oxy cutting system #5
I wonder if all torch makes can be used with this gas set up?
I sent Petrogen an Email asking about this, and here is what they said.
In order to safely deliver and mix the gasoline, everything is different: hose, torch, tank. tips. Tip numbers correspond to thickness cut. See cutting chart on Standard Package page in our Web site.
   / PETROGEN - gasoline/oxy cutting system #7
I just scratched O/A off my wish list and replaced it with petrogen.
I'm now in search of some project where I have to cut some insanely thick metal with an airgap between two layers.
   / PETROGEN - gasoline/oxy cutting system #8
Did any get any pricing yet?
I was looking at propane / oxygen but haven't made that move yet.
this looks like another alternative.
tom
   / PETROGEN - gasoline/oxy cutting system #9
tom
A quick web search indicated that they are pretty guarded about their prices. Everyone says to "call for pricing"
The used ones I see selling locally are advertised for a little over $1,000. I'd imagine new is a bit more than that.
   / PETROGEN - gasoline/oxy cutting system #10
I think I'll look in to the propane a little harder now.
tom
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
Miller Bobcat 225G Welder (A49461)
Miller Bobcat 225G...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
