Petro Canada Duratran Synthetic THF.
   / Petro Canada Duratran Synthetic THF. #2
Dead links here...
   / Petro Canada Duratran Synthetic THF. #4
Ahh yes Petro Canada, they make some great great oil's use it with confidence your getting a great product built well.
for instance look at some of there engine motor oil's, for example look at cold
flow properties. Check out the pour point of their Supreme 5w30
at -42 C and the cold cranking viscosity of 4710 cp @ -30 C. the cold-cranking values for their conventional oils are the lowest of ANY regular conventional out there witch means a great base oil has to be used to be able to reach that spec, you will see that their 'conventional' base oil is actually a group II/III mix, so the oil is technically a blend.
that was just one example, i wish this oil was available in the states i'd be all over it like stink on sh*t!
Wow, thanks for the vote of confidence. I wish you could buy it down there too. You should email them, and see what they say.
df.
   / Petro Canada Duratran Synthetic THF. #6
df.
As far as a few years ago(i checked) there was no distributors this side of the boarder i would have to cross over not worth the hassle,but you guy's are all set use it it's a fine oil!
   / Petro Canada Duratran Synthetic THF. #7
Gents,
There are several PC distributors in the US. We handle it where I am in Missouri and I know that there is at least one distributor in NE.
   / Petro Canada Duratran Synthetic THF. #8
Gents,
Really? Hmmm have a link or number for a list of dist?
   / Petro Canada Duratran Synthetic THF. #9
Petro-Canada America Lubricants
980 North Michigan Avenue
Suite 1400, #1431
Chicago, Illinois
USA 60611
Phone . . . . . . . . . . . . . . . . . 1-888-284-4572
Fax. . . . . . . . . . . . . . . . . . . . (708) 246-8994
E-mail. . . . . . . . . . . . . . . . . . email@petro-canadaamerica.com
   / Petro Canada Duratran Synthetic THF. #10
thank you...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
Towable Diesel Tank (A53421)
Towable Diesel...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
