pests VS. a METAL sided pole building..
   / pests VS. a METAL sided pole building.. #1
mopower440
middle tennessee
lawntractor only
wondering about something here, you know how the metal used in a pole barn has the raised ribs in it, well, where the metal attached to the skirt board, there will be those ridges every 9 inches or so, what do you people do to keep pests from getting in the building by going through these ridges? Im ready to order siding tomorrow, but am thinking twice now as i dont want any unwanted guests coming in through these spots?
   / pests VS. a METAL sided pole building.. #2
</font><font color="blue" class="small">( wondering about something here, you know how the metal used in a pole barn has the raised ribs in it, well, where the metal attached to the skirt board, there will be those ridges every 9 inches or so, what do you people do to keep pests from getting in the building by going through these ridges? Im ready to order siding tomorrow, but am thinking twice now as i dont want any unwanted guests coming in through these spots? )</font>
Mine is sealed with a spray foam insulation. You can purchase it in small cans and go around the inside of the building and seal up each opening.
   / pests VS. a METAL sided pole building.. #3
There is all sorts of trim to cover those edges, and you sure want it if anything you want to keep could come in contact with that knife edge...
   / pests VS. a METAL sided pole building.. #4
<font color="red"> (Mine is sealed with a spray foam insulation. You can purchase it in small cans and go around the inside of the building and seal up each opening.) </font>
I've been thinking about doing that in my shop. Those ridges sure let the critters in (especially the little furry ones). I'm either going to have to get a barn (shop) cat or go with the foam.
About how many linear feet of siding does one of those spray cans do?
SnowRidge
   / pests VS. a METAL sided pole building.. #5
There is a trim piece, I believe called 'rat guard', that I purchased for along that bottom edge when I sided the pole barn, and it is similar to the 'j' trim if I remember correctly.
Otherwise, a neighbor cut small squares (4" ?) of 1/4" hardware cloth, and rolled them like a cigar and slipped them into each opening. His thought was that the ants would eat through the foam. But, I don't know that would happen.
   / pests VS. a METAL sided pole building.. #6
Rat guard is the trim that is used.
   / pests VS. a METAL sided pole building.. #7
I don't know if the foam-in-a-can will be different from rigid foam insulation sheets. I saw some foam (with foil covering) that was like an ant farm, from mice burrowing through it..............chim
   / pests VS. a METAL sided pole building.. #8
Caulk or spray foam insulation?
Soundguy
who sells the rat gaurd? wonder if you could just use J-channel???
   / pests VS. a METAL sided pole building.. #10
It will hold alot of dirt and cause rust. There is also some shaped like an "L" that works well. Any place that sells panels should also handel trim.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
2023 WESSEX RMX500 LOT NUMBER 43 (A53084)
2023 WESSEX RMX500...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
