RancherGuy
- Joined
- Feb 2, 2010
- Messages
- 301
- Location
- Rosenberg, TX
- Tractor
- Kubota L3710; JD 5425, 6105R, 7130-P; IH 1086
I have a 4 cylinder JD 5425 - 65 PTO hp utility tractor by definition.
For two years, this has demonstrated power loss when I use it at full power when cutting hay. The crop is consistent density and I cut for hours. Power starts off great but can start to decline after 20 to 30 minutes. I shift gears when power declines to keep the PTO RPM up. I might downshift from gears 9 to 8, 7, or 6. My intuition is that the decline is fuel related.
I've changed the fuel filter twice, but I think the power revival is because the tractor was off for a while when changing. I've cleaned out the air filter, but again I think revival was because of the time while cleaning. Power losses resumed within 30 minutes after those rest periods.
This year I found something peculiar one day - started in 9th gear but had to slow down to 7th. Air temp at start was 94 degrees, but after sunset, temp was 88 degrees and power loss seemed to stop declining. Air temp kept dropping and I found that I could kick back up to 8th gear. What a revelation!
Today it got down to 7th gear, but a thunderhead appeared and there was a cool air blast. The engine was power revitalized! I bumped it up to 8th.
Here's the big question: there has to be a means to meter the fuel based on air density, right? To compensate for temperature and turbo pressure? Is there a Mass Airflow Sensor? I've looked at JD parts and can't find something that seems to fit the bill. I'm thinking that whatever the sensor is, it has become temperature sensitive. And at 16 years old, needs to be replaced. Any information? Any ideas?
