Rotary Cutter Perfecting a new Rotary Cutter
   / Perfecting a new Rotary Cutter #1
bill6
Kennewick, WA
...A few days ago I brought home a brand new Howse 500c 5-ft rotary cutter for use behind my Mahindra 2415. I'm rather particular about cosmetics, so even being "new", a clean-up seemed in order.
Evidently, the people responsible for shipping, handling, and assembly/set-up of these "bush-hogs" tend to be somewhat careless in terms of keeping the paint looking nice. In this case, my dealer had 5 to choose from, and I chose the best one. Still, there were several scratches and paint nicks!
I brought the implement into my heated garage and worked on it several hours each night this week, much to the dislike of the wife. (I work 8:30 to 5:30 at the office)
First, I rubbed out the paint by hand with Mcguire's fine-cut cleaner. It brought out a much better shine, removing most of the haze or cloudiness. Then I degreased by wiping every scratch and nick, with Isopropyl alcohol, in preparation for painting. Then I loosely masked off each small area I was going to touch-up. (about 10 areas in all). Then I bought a can of Massey-Ferguson Red. I carefully sprayed 4 very light coats, with 10-minutes drying time between coats. After removing the masking tape, it looked pretty good. The next evening I "blended in" the paint areas, by again using the rubbing compound.
Next, I applied 2 coats of car wax to the entire surface, including mounting brackets and gear box case. After buffing off the wax, it really looks beautiful! My wife was wondering what in the world I was doing out in the garage....
Next I safely blocked the big deck up off the ground. I crawled under, and applied car wax to the entire underside, and blades. Then I sprayed a product called "Mo-Deck" to the underside. It's a no-stick spray that enhances the ability to clean the deck later; usually the grass & weed build-up will just hose off. Then I adjusted and greased the PTO driveline, checked the oil in the gearbox, and finally greased and cleaned the tailwheel.
There.....now I have a beautiful, NEW Rotary Cutter, ready to go to work. It was a total of 10 hrs work, but hopefully worth it. Unfortunately, my wife invited me to stay out there and sleep with the tractor.......
   / Perfecting a new Rotary Cutter #2
Are you going to use it or take it to shows? :rolleyes:
Solo
   / Perfecting a new Rotary Cutter #3
That's nothing. I hand cut everything in the yard so that the bush hog doesn't ever have to get dirty. I never use it, but I drain and replace the synthetic oil every 3 days anyhow. I'm thinking about having it gold plated, then shrink wrapped and kept in climate controlled display storage. ;)
No, actually I set it on blocks out in the treeline and blow the grass off it with compressed air when I'm finished, and once in a while I sharpen the blades. And it had a leaking seal so I filled the gearbox with grease. And it was leaving windrows so I cut the skirt off the back.
   / Perfecting a new Rotary Cutter #4
Has anyone ever suggested a diagnosis of OCD/OCPD? There are medications.:)
Hi Island; let me guess.......over-cleaning disorder? and over-cleaning & polishing disorder?
Trouble is, now the rotary cutter looks so pretty, I almost hate to use it because it might get dirty.....
   / Perfecting a new Rotary Cutter #6
I believe the doctors prescribe Paxil for OCD. But after reading these posts...I believe "**** Retentive" maybe for appropriate.
   / Perfecting a new Rotary Cutter #7
I would like to see before cutting and after cutting pictures :D
of the mower
Jim
   / Perfecting a new Rotary Cutter #8
Mcguire's and wax on a bush hog? Aint that kinda like polishin' a turd? It might be all purty and shiney but still...:confused: :confused:
   / Perfecting a new Rotary Cutter #9
Polishing at rotary cutter?? That is wacky! :eek: Mine looks like afore mentioned turd....and I don't intend to polish it
   / Perfecting a new Rotary Cutter #10
Your poor wife...I hope you are at least helpful around the house if she ever lets you back in.:D
2018 John Deere 2025R Tractor - 647 Hours (A55314)
2018 John Deere...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2017 INTERNATIONAL DURASTAR 4400 (A55745)
2017 INTERNATIONAL...
1998 KENWORTH T800 DAYCAB (A55745)
1998 KENWORTH T800...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A55745)
30 INCH TOOTHLESS...
