Perfect Fit
/ Perfect Fit #1
Anonymous Poster
Epic Contributor
I really love this tractor, this fits perfect into my barn. I love that FEL, I was going to shovel all the manure out, but a few swipes and I will be done. Before and after pics to come.
/ Perfect Fit #2
Kinda clean machine you have there.
Now those pics.. BS? . Will the be pics be of the manure? Now that's a bunch of BS, or HS. ha.
/ Perfect Fit #3
T I G H T
FIT!
/ Perfect Fit #4
Looking above the ROPS,... I cut out 5 "
To each side at the bottom, I hacked away a BIG chunk, I later build little ugly doors for it.
AND... If you look inside the shed, in front of the loader, you will see I hacked a HUGE chunk off the front so the loader will slide through.
I later enclosed the "tumor", but it is ugly.
So, in summation, 12x8 is a tad too small for a BX2200 w/ loader and weights.
/ Perfect Fit #5
I have my father in law's '69 Mustang (he is 82 and original owner...), my wife's new Mini, and my 2002 L3010 in my garage. A 6.1 stereo, heated, insulated and plumbed. 34 x 28. super deluxe workshop.
All the while my BMW sits out in the rain!
Priorities...
/ Perfect Fit #6
rouge, the picture was pretty dark on my monitor so I lightened it up for you (see attached) in case others were also having difficulty seeing the detail.
/ Perfect Fit
Hey rogue, how does you're loader bucket shed addition look?
Last I read, you were going out to look at bigger sheds.
DaveL
/ Perfect Fit #8
I had the same problem, but took the opposite approach. The roof of my shed extension is 2x4's, plywood and shingles. My solution - lower the floor. Took alot of redoing but it worked. The trouble was the owners book said the top of the rops was 76". I built it 80". Then I tried backing in the first time and wasn't too happy. /forums/images/graemlins/mad.gif The actual height of the tractor was 86". Lesson learned - read that silly fine print, you know - specifications are subject to change without prior notice.
/ Perfect Fit #9
HA HA HA HA HA
Actually, the day I decided I had to hack my little shed and get my tractor in it (rather than the garage) was the day I happened upon a 1988 528e "CHERRY" and I wanted it in the garage. Later I had to bump it because I found a 1985 MB 300SE. I turned a few bucks on that one, it only had 50k miles on it "VERY VERY CHERRY". Now I'm back to two cars, but I guess we are now getting a Mi... Mi... Miiinnn... /forums/images/graemlins/crazy.gif
I can't say it... Honda Odessey I can say.. you'll have to figure out the rest.
So I guess The third vehicle and the tractor will have to fit in the new shed garage.
/ Perfect Fit #10
Hey Rogue:
We were looking at adding a two car garage last year. I tried to cheap it out but my wife kept pestering me and the builder to go bigger. Guess size is everything. Bottom line we ended up with a 28x32 garage/barn with loft. Glad I did it now. You would not believe how much stuff we keep in there...not to say that my boat and tractor fit in very nicely.
2015 Ford Fusion AWD Sedan (A61574)
2015 Ford Fusion...
2014 INTERNATIONAL DURASTAR 4300 EXT CAB DUMP TRK (A64280)
2014 INTERNATIONAL...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
Caterpillar D6D Tractor Service and Parts Manuals (A63117)
Caterpillar D6D...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
Speader (A64194)
Speader (A64194)
