Perfect Cross between Kioti 45 and BX 2200
   / Perfect Cross between Kioti 45 and BX 2200 #1
nc redneck
Platinum Member
Apex nc
Kioti Dk45SE Sold Kubota BX 2200 Sold Kubota B 3200 Loader WR Long 4 in 1
I believe I have sold farm much to my regret. If buyers back out it may be best day of my life. I have a hst kioti 45 and bx 2200, both of them great machines. If you were looking replacement for both what would you get ? Bx is tough and will do 90% of what I need but loader lift is weak and height is not much. Must have a belly mower. I looked at BX 25D spec hard but not much different than BX 2200. It must he a HST.
Thanks
Scott
   / Perfect Cross between Kioti 45 and BX 2200 #2
Hmm, I'd probably look at a B2650 if you need a little stronger loader and more ground clearance.
   / Perfect Cross between Kioti 45 and BX 2200 #3
If the BX is to small move up a size to the B series
   / Perfect Cross between Kioti 45 and BX 2200 #4
Kioti CK series.
Or kubota L-series. I think you can get a MMM on the grandL line, but not sure. IF it wasnt for that, I'd say an L3200/L3800 would be a nice fit.
   / Perfect Cross between Kioti 45 and BX 2200 #5
I second what S219 said, a kubota 2650 is a nice unit, a friend of mine just bought one, he really likes it and those do not have the tier 4 junk on them either.
   / Perfect Cross between Kioti 45 and BX 2200 #6
No belly mowers on Grand Ls. Awfully big rig to be mowing a lawn with.
I 3rd (or 4th or whatever) the B-Series. My uncle has one and loves it, though he doesn't mow with it.
   / Perfect Cross between Kioti 45 and BX 2200 #7
A Mahindra Max.
   / Perfect Cross between Kioti 45 and BX 2200 #8
My mistake. I thought they had MMM option.
I know deere 3x20 series does. Or at least did. Which is comparable to the Grand L 3x40 series
   / Perfect Cross between Kioti 45 and BX 2200 #9
The Grand L's did have the mid mount mower option at one time.
Not sure when or why that changed.
   / Perfect Cross between Kioti 45 and BX 2200 #10
Ah, so maybe I wasnt mistaken.
I'll agree, its a bit large for a mower. But like everything, when trying to consolidate two pieces of equipment into 1, there will be compromises.
So you can either have a heavy lawnmower that has the loader capacity you need. Or a lighter (better) mower that may lack a bit in the lifting department
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
