Penetrating oils tested
   / Penetrating oils tested #31
Found this on different forum; interesting:
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
The above has one typo (which was in the original article as well): Instead of ATF it should be PSF (power steering fluid).
See http://sterkel.org/systems-engineering-associates.com/papers/avocations/Testing_Penetrating_Oils.pdf
   / Penetrating oils tested #32
In many cases.. atf / ps fluid is just about the same.. etc..
soundguy
   / Penetrating oils tested #33
I've seen Kroil for sale at Wal-Mart.
   / Penetrating oils tested #34
That's be neat.. i'll have to check my local store..
soundguy
   / Penetrating oils tested #35
I hit a lot of WalMarts in my travels at work, they usually have clean bathrooms and I like to browse for closeouts.;) I've never seen Kroil but I hope they do start carrying it around here...I always have to mail order it.
   / Penetrating oils tested #37
I bought Kroil when I was working on a car that had sat for 15 years. I sent away for it . Just about everything was frozen in place . I did a lot of spraying ,tapping and waiting to free things up. The Kroil paid for itself as nothing broke or stripped. For everyday use I use WD 40 or PB.
John
black Max power washer (A53421)
black Max power...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
2015 DODGE RAM...
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A54607)
2017 CENTAURO...
2012 Honda Accord Sedan (A55758)
2012 Honda Accord...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
