peljob721 mini digger hydraulic problem
   / peljob721 mini digger hydraulic problem #1
peljob721
uk
peljob721 1998
hi all im new to the forum im hoping someone can help me ive got a peljob 721 1998 mini digger and the hydraulics are slow and when either of the hydraulics are on full lock it nearly stalls the engine and it dose the same when i try to turn on the spot with the tracks eny info would be great
   / peljob721 mini digger hydraulic problem #2
Is your hyd system open center or closed center?
Have you checked the filters?
Have you checked the pressures on the loader and the drive motor valves?
Do all the return lines have good flow to tank with no obstructions?
hi im new to hydraulics but i will try my best to answer to start with what is open/closed hyd system ive just put a new filter kit on it no difference but what ive noticed today is that all the functions ie tracking/moving arm apart from the bucket curl have got very erratic movements ive also taken it down to get pressure tested and all good
   / peljob721 mini digger hydraulic problem #4
If you have any QD's in the hyd system, reset them. Unplug and plug back together.
Has someone been doing work on the machine?
Open center hyd is when the fluid is flowing through all the time.
In a closed center hyd system, the fluid is at the IN ports not flowing, but available for use.
where are the qds in the hydraulic system also ive just been looking at the hydraulic box where all the pipes valves ect go and i have got 3 valves with screw caps with little chains on them and on the side of the box is a yellow caps on valves what are these
   / peljob721 mini digger hydraulic problem #6
These fittings are QD's, Quick disconnects..
Surplus Center
Do you not have an owners manual?
yes i have 2 quick disconnects for breaker ect i have an owners manual on order what would be the 3 screw cap valves on top of the hydraulic box
   / peljob721 mini digger hydraulic problem #8
Show some pictures.
   / peljob721 mini digger hydraulic problem #10
What I am seeing is solenoid valves showing the solenoids with two large screws on top.
Some solenoid valves have a manual way to activate the valve.
The screw also lets you change the solenoid.
You can test the valve by using the correct voltage, and air as the source.
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
2001 TOYOTA TACOMA SRS TRUCK (A54756)
2001 TOYOTA TACOMA...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
40006 (A55788)
40006 (A55788)
2013 FORD EXPLORER (A54756)
2013 FORD EXPLORER...
2019 MDB FM180 FINISHING MOWER (A51406)
2019 MDB FM180...
