pedal on 1610TS
/ pedal on 1610TS #1
Rambo
Hello, I have a 1610TS and I believe that my rear wheels are in lock position from the differential pedal. I believe that it may be frozen and was wondering how to go about releasing it. I noticed that the differential pedal is very hard to mash down and very hard to pull up with hand. It should be more freely then it is. I jacked up one side and the wheel would not rotate so that's how I know that it is stuck. Thanks.
Rambo
/ pedal on 1610TS #2
the transmission would have to be in nutrual before you could turn the wheel. When you turn a tight circle the inside wheel should turn slowl, The outside wheel should turn faster. If this is true the differential is not locked.
/ pedal on 1610TS
When I had the one side up I did put it in neutral and it still will only rock back and forth. It will not go all the way around. That is when I figured it was stuck, since it would not spin. Thanks.
Rambo
2020 Deere 50G (A64119)
2020 Deere 50G...
iDrive TDS-2010H...
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
(2) Bell 500 Gal Saddle Tanks (A64119)
(2) Bell 500 Gal...
