pedal on 1610TS
   / pedal on 1610TS #1
Rambo
Hello, I have a 1610TS and I believe that my rear wheels are in lock position from the differential pedal. I believe that it may be frozen and was wondering how to go about releasing it. I noticed that the differential pedal is very hard to mash down and very hard to pull up with hand. It should be more freely then it is. I jacked up one side and the wheel would not rotate so that's how I know that it is stuck. Thanks.
Rambo
   / pedal on 1610TS #2
the transmission would have to be in nutrual before you could turn the wheel. When you turn a tight circle the inside wheel should turn slowl, The outside wheel should turn faster. If this is true the differential is not locked.
   / pedal on 1610TS
When I had the one side up I did put it in neutral and it still will only rock back and forth. It will not go all the way around. That is when I figured it was stuck, since it would not spin. Thanks.
Rambo
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2009 Pontiac G6 Passenger Car (A51694)
2009 Pontiac G6...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
