PEC MISSING PINS
   / PEC MISSING PINS #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I received Pat's Easy Change in the middle of April this year. Installation went smoothly and quickly. Since I'm not as organized as I could be in my quest to develop food plots for deer at hunting camp, I change implements frequently. Works great. Problem encountered today after spraying RU on 4 newly cleared acres, I noticed that one of the hooks was slightly misaligned with the lower link. When I looked closer, I realized that the 3/4" diameter by 2" long crossbolt that secures the hooks to the lower arms through the hole in the arms had slid about 1/2" to the inside, not catching the outside of the hook bracket. I found an empty hole about 1/8" through that pin where a keeper pin had been. Checked the other side and the keeper pin was missing, but the 3/4" crossbolt was in correct position. I don't have the original directions. I'm not sure whether they were simply cotter pins that worked loose somehow or what. The other ends of the crossbolts have roll pins about 3/16". If I can't get some help, I'll call Pat's tomorrow. But it just goes to show that you have to regularly check your equipment.
   / PEC MISSING PINS #2
Being that I just installed mine - yes, they are just cotter pins you are missing.
Good idea to check things over once in a while!
   / PEC MISSING PINS
Much appreciated. Looks to be about 3/16" diameter hole in crossbolt.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2012 Ford Explorer SUV (A53117)
2012 Ford Explorer...
