pcv
   / pcv #1
Anonymous Poster
Epic Contributor
Do these little diesel engines have pcv valves? I'm guessing they do.. but I can't recall where they are located? Or is the oil dipstick the positice crankcase vent? <G>
thanks
Chris
   / pcv #2
My 3 cyl. engines all have a crank case vent on the top of the valve cover with a hose going down the side of the motor.
   / pcv #3
My 2cyl yanmar has the "road draft" style of vent tube. Larger diesel's such as Detroit V6's and V8's have a PCV like device called a "spitter valve". As for Yanmar using a check valve like this, it would be in the engine section of the parts manuals. Len, Roger,and a couple of others can be more specific.
Good question tho... the idea behind there useage is to lessen the amount of condensation in the oil.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
