Forks Payne Clamp-On Forks
   / Payne Clamp-On Forks #1
N1ST
Enfield, CT
Kubota B7800
Anybody know how to clamp on forks and not make an indention in the bucket? I have the medium duty and with the way they're designed (with no support directly under the bucket in line with the clamp bolt) it seems there's no avoiding making a bowl shaped dent in the bucket where ever you mount them.
   / Payne Clamp-On Forks #2
I added a 3 inch disk to distribute the pressure on my homemade clamp-on forks.
I was thinking about something similar. I guess I'll call a welding shop and see of they have some scraps. Nice looking forks from what I can see.
   / Payne Clamp-On Forks #6
I'm curious about the lift capacity of clamp on forks. Seems like you could bend up the bucket in short order if you go after to much. Any thoughts?
   / Payne Clamp-On Forks #7
Most of these buckets have only 1/8" steel carcasses. You must do
something to protect the thin steel from deforming. Attaching some steel to
spread the load like MJFOX did is a good solution. The current owner of
one of the Kioti CK30s I bought has punctured his bkt with this kind of
clamp-on fork. :-(
   / Payne Clamp-On Forks #8
clamp-on fork. :-(
I have been using the light duty set for nearly 4 years .and haven't run into any of the above problems.
Just don't get carried away and over load them an use a little common sense and they do fine.
*He must have the strength of 12 men to do that.
I found a pair of "stabilizer brackets" at TSC that are perfect for spreading the load on the top side. $10, painted, at least 1/4" thick, and you get a pair of cat 1 pins and lynch pins to put in your spare parts bin. Item # 0267911.
Now I'll be looking for something to put under the bucket to prevent a crease. I'll check to be sure there's not a better way to mount the payne forks to prevent this.
   / Payne Clamp-On Forks #10
My light duty forks clamp on top of my Markham Toothbar... Kind of a win-win...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
2017 Chevrolet Silverado Schwarze SuperVac Updraft Sweeper Truck (A55852)
2017 Chevrolet...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
