Pats. Why bent washers?
   / Pats. Why bent washers? #13
I bent a pile of them myself , i have 7 or 8 sets , i also welded much bigger washers to them on the inside, Makes it even easier to hook up, I had my pto spreader bounce off one side once when it was empty, The larger washer helps prevent that, Love my pats,
   / Pats. Why bent washers? #14
have had pats for 5yrs. tried the spreader bar and that didnt work. everything was different widths. washers... havnt a need for them sofar.
   / Pats. Why bent washers? #15
Man!! At that price I could easily bend and drill a whole lot of standard washers.
   / Pats. Why bent washers? #16
I have seen where poeple measure each implement and mark the spreader bar for each then just adjust it when you change implements, I used mine for a while then decided i did not need it, Most of my implements are very close to the same width i can do without.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
2003 Big Tex 10PI...
2018 CATERPILLAR 259D SKID STEER (A52707)
2018 CATERPILLAR...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
VOLVO DD120B DBL DRUM ROLLER (A52707)
VOLVO DD120B DBL...
