pats quick hitch on 2610
/ pats quick hitch on 2610 #1
Stonefox
Bronze Member
Butte, Montana
2016 Kioti ck2610 hst cab
Hi all, I am considering buying Pat's quick hitch for my 2610 and was wondering if anyone was using it and if I will need to get a longer top link.
Thanks!
/ pats quick hitch on 2610 #2
I have a 2610 I bought new in November of 2016. I had a John Deere 850 before that. Switching between a grader blade and a rake was always a pain. So when I got the Kioti, I figured I would give Pats a try.
As long as you follow the directions they go on nicely, and work great. I have not had to use a longer arm for my use.
Thanks Sheldon! I've had some back issues and switching between the RFM and rear blade is a chore that I am looking to make easier.
/ pats quick hitch on 2610 #4
I have the pats qh on my mahindra 2538 and it works good ,But on some of my implements the top link is all the way out.Im going to get a longer one so i have more room to play with. Rural king has them for under 30 bucks.
/ pats quick hitch on 2610 #5
Pat's easy hitch will move the mounting point back 4 inches.
So a longer top link will help keep from over loading one that is played way out and not prone to snapping....don't ask....heh...
/ pats quick hitch on 2610 #6
Bought pat's quick links, like them very much. Top link is hydraulic, so no reach issues. As noted follow the instructions, use the proper provided shims.
Thanks majorwagner, I have also been considering a hydraulic top link but at least a longer manual link is not that expensive as 3gunr has said.
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2024 John Deere 3025E (A64911)
2024 John Deere...
Easy Lawn TM35 (A64911)
Easy Lawn TM35...
