Pats on adjustable lower links
   / Pats on adjustable lower links #1
TheMadOne
Platinum Member
USA
Kubota L3560HSTC-LE, formerly L3301
I'm going to look at a L3560 to replace my L3301. I have a set of Pat's Easy change for the L3301. Do they play nice with the adjustable lower links on the Grand Ls, or should I budget for a traditional quick hitch and leave the Pats on the L3301 for the next guy.
   / Pats on adjustable lower links #2
Our MX5800 has the adjustable lower links and I bought the Pat's system for it. Works well. I bought the version of Pat's that fits Cat 1 implements but a Cat 2 lower lift (all of our implements are either Cat 1 or are both Cat 1 and Cat 2 compatible). I would buy a traditional quick hitch but a/ our ballast box lift pins are too far apart for the Cat 1 quick hitch and b/ some of our implements are not quick-hitch compatible, although most could be made so using a adapter.
   / Pats on adjustable lower links #3
Check with Pats.....they used to make one that replaced the adjustable part.
2018 JLG 3246ES ELECTRIC SCISSOR LIFT (A52707)
2018 JLG 3246ES...
Reynolds 14C 14 Yard Dirt Pan (A53317)
Reynolds 14C 14...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
(18) 10" X 15.3# CAHNEL IRON (A57192)
(18) 10" X 15.3#...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
2006 iDrive...
