Pat's Easy Hitch?
/ Pat's Easy Hitch? #1
MUDONTHETIRES
Northern Louisiana
Mahindra 6065 4WD
I'm getting a Mahindra with extendable lower links. Does anyone know if Pat's Easy hitch will fit them. I've always used Pat's and want to on this new tractor but I'm not sure they will fit flush on the extendable arm.
Thanks in advance!
/ Pat's Easy Hitch? #2
I love my knock off Pat’s. I won’t call a name due to poor memory on my part. However a buddy has the lengthening lower arms on his tractor, and it makes hooking up implements a breeze with no additions. Once connected, he backs up and the lock into place. So much better than the fighting that lead me to Pat’s snd then what I bought on a 1/2 price sale.
Try your new ones and while testing them you should be able to determine if Pat’s will fit.
/ Pat's Easy Hitch? #4
Kioti also has extendable arms, and Pats works just fine. Its your implements your going to struggle with on their pin setup. But once you get the pins done right for each implement, your going to love Pats.
/ Pat's Easy Hitch?
Thank you!
/ Pat's Easy Hitch?
Thank you!
/ Pat's Easy Hitch? #8
I have Pat's on the 35 and extendable links on the 33. Gotta get out of the seat to connect PTO shaft or adjust the top link any way. I prefer the adjustable draft links and would pay extra if they were an option vs std. IMO they're the easiest to line up when connecting, but Pat's was a good investment without having them.
btw, I don't use glue with tape, but that's just me.
/ Pat's Easy Hitch? #9
How is a good investment in Pats without having them?
/ Pat's Easy Hitch? #10
'Them' = extendable draft links. I've had Pats' on my 35 for several years, began my post with the mention, and appreciate the convenience w/o extendable links.
I've never had to fuss with my PEC, but learned to remove the spreader bar after connecting to it. Otherwise it'll fall out.
I'd have bought PEC for the TC33DA too if it hadn't come with extendable links. (AKA 'them' ;))
btw, still offering my HFT Cat 1 3PH QA for sale. Got $50 and live close by?
IMO Pat's is easier to use o'all w/o having to mod non-ASAE spec attachments of futz with bracketing for the top link.
/ Pat's Easy Hitch?
Very helpful, thank you!
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2004 TOYOTA7F GU26 FORK LIFT (A59914)
2004 TOYOTA7F GU26...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
20ft Driveway Gates (A65579)
20ft Driveway...
Bush Hog 3Pt Post Hole Digger (A66408)
Bush Hog 3Pt Post...
