Pats easy Hitch
   / Pats easy Hitch #11
Can't you stack the shims (under the lift arm)? Or do no combination of shims work.
I wouldn't worry about the lower (side) threaded hole being below the lift arm. I started to question the need for those bolts after bending the weak bolts supplied with the Pat's, then replacing them with a stronger Grade, then bending them too, then snapping bent bolts off trying to extract them, then having to take it to a machine shop to extract (I screwed it up REAL good!). (Hint: Cut bent bolt in interior before trying to extract.)
Lately I've been wondering if the Pat's should be left loose (side-to side) so that it mimics the action of the swivel ball in the lift arm that gets eliminated by the Pat's. Being fixed (side-to side) seems to cause too much stress on these bolts.
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2018 Nissan Pathfinder (A56859)
2018 Nissan...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
