Pat's Easy Change Pat's Easy Change System
/ Pat's Easy Change System #1
tractorwheel
Pat\'s Easy Change System
I am spending way too much time hooking onto the brush hog. Whether it is with my little hinamoto or my big /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gifkioti. I find I am having to use the big hammer alot. Would this make my life easier? My brushhog is old but is still working great, just the hook up situation. Thanks.
/ Pat's Easy Change System #2
Re: Pat\'s Easy Change System
Pat's Easy Change isn't a miracle, but it sure makes hooking up an implement easier.
I definitely recommend it..it'll knock off several minutes and a lot of strain, pain and foul language!
/ Pat's Easy Change System #3
Definitely easier. I use my brothers 5' mower and he keeps it backed in the corner in his building, I can back in and raise my lift and latch onto the bottom pins without getting off the tractor, and drag the mower outside and finish hooking up after I get it outside. I would sure hate to do without the easy change.
/ Pat's Easy Change System #4
And I'll echo Roy and Milkman. I just got mine and I love it. It makes hooking up a LOT easier. If you hook up alone it's a lifesaver. It really cut out the colorful language when hooking up my rough cut mower.
/ Pat's Easy Change System #5
Pat's was the first attachment I bought for my tractor after it was delivered. Makes it a lot easier to hook up. Highly recommended. Not as fast as a quick hitch, but usable with all implements. A quick hitch sometimes requires that implements be modified. At least that's what I've read here.
/ Pat's Easy Change System #6
I highly recommend the Easy Change System. Had mine for about a year and it hasn't disappointed. I think nothing of changing attachments with this system. Before I would dredd changing. /forums/images/graemlins/mad.gif
Get it...........you won't regret it!! /forums/images/graemlins/smile.gif
/ Pat's Easy Change System #7
A couple of Sat's ago I was at an estate auction and ran into an acquaintance that works at Pats and he asked me to stop by and see the new machine they had. Yesterday I had some running to do so I stopped by Pat's Easy Change factory. They have a new CNC machine that is just fascinating to watch, just pick a job on the computer and push a button and that thing has a mind of its own. Nice clean place neatly organized, but laid back with a pot of coffee going , if you ever get a chance, stop by and get a cup and take a tour, I could have stayed all day. /forums/images/graemlins/cool.gif
/ Pat's Easy Change System #8
One thing to watch out for with Pat's system is the fact that the load is placed about 3 inches further back from the tractor. If you have a heavy three-point implement that is near the handling limits of the tractor (the front end gets light when the implement is raised), this extra 3 inches will make the problem worse. The heavy weight is now at the end of a 3 inch longer lever arm and may raise the front of the tractor off the ground.
I'm putting Pat's system on my L4300. I have a Woods BB720 bush hog that is about 300 lbs. heavier than the max recommended bush hog weight for the L4300. Without the FEL in place, the L4300 is marginal with this mower, at least in 3-pt. mode. In 2-pt, it's no sweat as the tailwheel stays on the ground; but 2-pt. can lead to scalping on uneven ground.
I'm expecting issues using Pat's system when I use the BB720 in 3-pt. mode on the L4300. But, even with that, I think it's worth it. Hookup/unhook from the BB720 typically takes a half hour and requires partial disassembly of the 3pt. hitch. I'll use it 2-pt. Where the ground is uneven enough to require 3-pt., I have a bigger tractor....which hooks up easy.
Bob
I appreciate all the responses. Christmas is coming and guess what I have asked the hubby for? /forums/images/graemlins/smile.gif
/ Pat's Easy Change System #10
Mom had asked me what I wanted for Christmas a few days ago, guess what I told her that I wanted? She came down last night and we logged on to TBN and ordered it.
/ Pat's Easy Change System #11
Hey there
Hooking up the the 3 point to implement doesn't seem to be a problem for me. It's that darn PTO shaft hook up to the PTO shaft to the implement. That darn hook up to tractor, just have hard time lining up. Get grease all over hands etc. That's the part I don't like. Is there an easy way to do that?
Cheers...Coffeeman
/ Pat's Easy Change System #12
Practice, patience - and gloves
//greg//
/ Pat's Easy Change System #13
I was afraid the answer was something like that.
/ Pat's Easy Change System #14
I had the same problem with my Rhino cutter PTO. I took a small file and filed a bevel on the teeth. It helped a lot. The tractor PTO shaft is hardened so you won't file it. A small grinder could help. Overall, a very slight bevel - 1/16" or so, helps you get the shaft started.
As far as quick hitch goes, my Speeco is tops. I plan to buy a second and put it on my FEL so I have a long boom pole.
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
