Pat's Easy Change Pat's Easy Change System..ANY downside???
   / Pat's Easy Change System..ANY downside??? #1
wksinatl
Atlanta
case IH 485
Pat\'s Easy Change System..ANY downside???
Is there any downside to Pat's Easy Change System? I've read lots of post but want to get the "latest and greatest" opinions.
thanks,
Keith
   / Pat's Easy Change System..ANY downside??? #2
Re: Pat\'s Easy Change System..ANY downside???
May need to shorten a PTO shaft.
May not work with a 3PH backhoe.
   / Pat's Easy Change System..ANY downside??? #3
Only problem I had was that my top cylinder was just a tad too short for some of my implements once the easy change was on -- just replaced it with a longer ($$$) cylinder.
   / Pat's Easy Change System..ANY downside??? #4
Homebrew, don't you mean "lengthen" the pto shaft? I had to on my tiller as it pulled apart after installing Pat's.
The system is well worth the $$$ in my opinion--makes installation/removal so much easier.
Ron
   / Pat's Easy Change System..ANY downside??? #5
I had to get a PTO extension for my rotary cutter. Here's a link to a previous discussion on the subject. Not a specific drawback to Pat's, but in general for all quick-change hitches that put the implement further away from the PTO shaft.
   / Pat's Easy Change System..ANY downside??? #6
Yep, thanks for the correction Ron ... I had my thoughts confused with adding an o/r clutch which I installed at the same time as Pat's.
Chrres!
   / Pat's Easy Change System..ANY downside??? #7
Is anyone using this device on a JD 4310? I am interested in buying one but I am not sure it will fit on my 3 pt hitch lift arms. Information on Pat's web site states "Requires approximately 4" of straight arm". My tractor does not meet this requirement. The lift arms angle in almost immediately. I emailed Pat's and the reply was that it would work but I am still somewhat skeptical. Can anyone confirm this?
Jim
   / Pat's Easy Change System..ANY downside??? #8
I've got the same thing going on with my TC45. I've got the adjustable arms and don't have those 4" either. I emailed Pat's with the same question, got the same answer, but have the same skepticism. Hope someone here can give us a good answer. I doubt Pat's would give us any trouble returning it if it didn't work ... I'd just hate to go through the time & trouble -- if I lived where my tractor lives I would - but it's 3 hours away which makes doing anything on it just that much more of a problem. And... when I'm there I need to be on the seat - getting the work done .. I only have weekends available.
   / Pat's Easy Change System..ANY downside??? #9
I just purchased a Gearmore quick hitch (GQH) instead of Pat's. I had been leaning towards Pat's at first, but decided against it. The primary reason was Pat's only dealt with the lower arms, which meant I would lose some adjustment capability in my upper link - the quick hitch would effectively "extended" the lower arms by about 3-4". I wasn't sure if going with Pat's would be a problem lining up since the lower arm spacing was dictated by whatever the stabilizer's could provide. The Gearmore had fixed spacing which matched up fine for my implements. I also like that it picks up all three points on the implements at the same time.
Michael_C,
How 'bout some pics, prices, where to buy, etc?
thanks.
Keith
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
Homemade Head Cart (A50514)
Homemade Head Cart...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
