Pats easy change problems
   / Pats easy change problems #1
bdog
Elite Member
Texas
John Deere 6130M
I ordered the system after hearing everybody talk it up and I have mixed feelings on it so far. Out of the three implements I use the most - box blade, tiller, shredder - it only works on the tiller. The rectangular guard on top of the easy change hits the braces on both my shredder and box blade. I can trim the braces with the torch and make it work on all of them but from what I read I thought these worked on darn near everything. I really would have prefered a true quick hitch but I did not want to have to modify my implements but it looks like I get to anyway.
   / Pats easy change problems #2
Can you show some pictures of the problem you're having? I just don't get why you can't use it. I have no problem whatsoever getting on everything I own. Tiller, boom pole, disc bedder, boxblade, landscape rake, brush mower, should I go on?
Maybe a picture will help me help you. I just can't imagine the problem as described.
John
   / Pats easy change problems #3
This is the first time anyone has mentioned this type of problem, pictures would certainly help. Would reversing your pins to point the opposite direction help?
   / Pats easy change problems #4
Same here on just one of my implements. My backhoe. Unfortunatly it can't fit the way it is manufactured.
It will work on my other toys however but I use my BH all the time so I ended up not using it.
Anyone want it cheap?
-Terry
   / Pats easy change problems #5
I've used it without any problems or modificaitons on 2 different brands of box blades, 2 different brands of landscape rakes, 1 rotary cutter, 1 rear finish mower, 1 PHD, 1 carry all/3pt sprayer, 1 seeder, 1 JD planter, 2 different brands of back blade, 1 sub-soiler/middle buster, 1 tiller. I did have to modify a Weight Box to get it to work!
So since I did have to modify the weight box, I can see that it might not be totally universal, but I really think pictures would be very helpful.
I will try to take a picture tomorrow. Reversing the pins would solve that problem, but then the lift arm sway bars would be too wide and would rub my tires. My box blade and shredder have the pins pointing inward and came that way from the factory. I only have about 1" between the sway bars and tires.
Also let me add that I can hook up to these implements but I can not fully lower them. The hitch binds when I try to lower the implement.
   / Pats easy change problems #8
There's something wrong with this picture. I have never heard of pins pointing inward from the factory. I suspect these implements are much too big for your tractor and your dealer pointed the pins inward to get them to work.
   / Pats easy change problems #9
</font><font color="blue" class="small">( There's something wrong with this picture. I have never heard of pins pointing inward from the factory. I suspect these implements are much too big for your tractor and your dealer pointed the pins inward to get them to work. )</font>
Older Massey Ferguson sickel bar mowers had the lower link pins pointed inward. SOME models of Woods mowers have outward pins for CAT II, and inward pointed pins for CAT I hook-up. Although rare, there are a few more cases where the lower link pins point in.....
   / Pats easy change problems #10
I am beginning to wonder is the lower lift arms aren't on backward or reversed. If you could get a picture, maybe we could help.
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
B&W 5th Wheel Hitch (A53117)
B&W 5th Wheel...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2015 Chevrolet...
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
