Pat's Easy Change or Quick Hitch ?
   / Pat's Easy Change or Quick Hitch ? #1
fidowanttobe
Platinum Member
Mandan ND
Jinma 284 2007 Massey Harris 44 Special
Has anyone out there had the chance to use them both and decide which one is best? I am undecided. Thanks.
   / Pat's Easy Change or Quick Hitch ? #2
Not both but I have a quick hitch. I had to modify a few implements to work successfully, coupled with a hydraulic top link is the way to go. Without a hydraulic top link I don't think it would be that much better than the pats system.
   / Pat's Easy Change or Quick Hitch ? #3
Nope, never used Pat's because I went out as soon as we got a tractor and bought a HF QH, and it has worked so well we never looked back.
This always ends up like a lot of other topics on TBN, where people either love what they have and are using; or they had a negative experience and end up hating it and then become rabidly in favor of whatever they buy afterwards to replace it, and then again there are some people just aren't capable of being satisfied.
There are numerous threads on the Pat's EC vs the QH flavor of the day, vs whatever other makes there are, I know because I read most of them and even took part in some of them.
   / Pat's Easy Change or Quick Hitch ? #4
Have used both and like the Speedco Quick Hitch. I don't use the hook for top link connection there is a u shaped brkt that comes with some brands. If your equipment is compatible suggest you modify it to work. well worth the effort.
   / Pat's Easy Change or Quick Hitch ? #5
It depends on whether the 3 point attachments you have meet the category dimension specs. Mine do not so I have to use Pat's system because a QH doesn't fit them.
   / Pat's Easy Change or Quick Hitch ? #6
I have used both the HF quick hitch and the Pat's. Once I realized the HF unit would not fit all of my implements, it went back to the store. I have since been using the Pat's for several years and have been pleased with it overall. Cost is a factor but I did not feel the desire to modify anything to make the HF work. Measure your implements and see what if any will fit. Good luck.
   / Pat's Easy Change or Quick Hitch ? #7
Look down at the bottom of this page for "Similar Threads". You'll get all the input you want and more.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
