Pat's Easy Change Pat's easy change compatibility question
   / Pat's easy change compatibility question #1
leftturn7m
Hello all...I have a quick question.
Does anyone know if I could use a Pat's easy change CAT. 2 on a CAT. 1 with shims on the lift arms?
   / Pat's easy change compatibility question #3
Sure. But I don't know why you'd want to do something like that. Cuz besides a lot of shims, you'd also have to get you hands on some Cat 1 pins for the lower lift arm swivel balls - and then add adapter bushings. Plus - once you have a Cat 2 PEC on a Cat 1 lift system, you need even more adapter bushings to pick up Cat 1 implements.
In the Navy we had a saying about this kind of lashup - it had something to do with a buncha monkeys and a football
//greg//
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2021 CASE TV450B SKID STEER (A51242)
2021 CASE TV450B...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
2018 GENERAC MAGNUM PORTABLE S/A LIGHT TOWER (A51243)
2018 GENERAC...
