Pasture Mgmt.
   / Pasture Mgmt. #1
Texpolo1106
West Texas
Kubota L3010 HST 4x4 w/ FEL
Hey everyone! I have a 5 acre pasture that I needs some work. Weeds are starting to take over and there are bare spots all over. I have a sprayer and I am planning on getting a plug aerator. My initial thought is to spray PasturePro to kill the weeds and then start aerating. Just wondering if I am on the right track here or if I need to include another step to renovate the pasture. :confused: Thanks!
   / Pasture Mgmt. #2
We have the New USA made Core aerators made by Tarter. 5 ft $1095. Ken Sweet
   / Pasture Mgmt. #3
First thing you need to do is to talk to your Ag Agent. They will give you advice on what to do and when to do it. Weeds are funny things. Spray them at the wrong time, and you just wasted your money. Time it right, and the results can be amazing!!!!
I was told to plan on it taking five years to get a pasture in really good shape. First you need to do a soil analysis to find out what your soil lacks. They will want to know what you will be growing on that dirt, and it's purpose. Grass can be for grazing or haying or just to look pretty. Different types of grass do better in differnt areas. Are you sure you have the best grass for your soil and climate?
Identifying the weeds is extremly important. You want to buy a chemical that will target those weeds, but not hurt your grass. You also need to know what time of the year the chemical works the best on the weed.
Every year, you will get a certain percentage of the weeds killed, and the soil will be a little better. First year, the results can be pretty impressive.
Good luck,
Eddie
Then you should identivy what weeds are
   / Pasture Mgmt. #4
Where I live if I spray it is mid June to kill bitterweed, pigweed or pokeweed. I have some other areas of weeds I spot spray. One good spraying at the right time got rid of most of the weeds (bitterweed) that were annoying. After that spot spraying with a big all pastures spraying ever few years. Actually I spray in the pastures the horses are not in. The horses go back in sprayed pastures after a good rain. Hand pulling bitterweed but that gets to be chore sometimes with 9 acres. Then I might be allowed to spray again.
Folks like to lime this time of year after a soil test.
If it is just one pasture and you are keeping livestock on it then you have a challenge. Our 8/9 acres is chopped up into 4 turnout areas. 2 big and 2 smaller. That lets the grasses recover from grazing assuming we have rain in the summer.
   / Pasture Mgmt. #5
How many and what animals are grazing that little field?
   / Pasture Mgmt. #6
Just saying if it was mine ... I would first thing "control burn" it off. Then determine what grass I want to dominate ... take a soil sample in to the extension office and specifically state I am growing ____________ Grass. Lime and Fertilize per the soil test and subsoil it ... I like Grazon for weed control cause it has a residual.
Thats just me though ....
   / Pasture Mgmt. #7
Over grazing causes weeds about 99 percent of the time. Rather than applying sprays spend you money on fertilizer and let the land lay fallow for 3 years.
   / Pasture Mgmt.
Eddie: Talking to the local agent sounds like a good idea for sure. From the research I have done it looks like PasturePro will get most of the weeds we have. The biggest problems out here have been sandburs, broom weed and some blue weed that I cant ID. I guess its just dumb luck but I figured on about 5 yrs to renovate.
Generally we will only have a few horses in the pasture. every once in a while we might have a few cattle turned out but that would be rare.
Thanks for all the info guys! This forum has been more help than I can say.
   / Pasture Mgmt. #9
Try to avoid spraying because. YES, it will destroy weeds but it will also do much more than just that. It will in all likely hood kill many insects, and for a period of time disrupt the ecosystem of the land if you will. I know spraying seems very easy, if you can try to just let it lay fallow for a few years.
   / Pasture Mgmt. #10
Good luck with the sand burs ... other than removing them with a hoe I don't know. Is this picture the blue weed?
FUEL TANK/TOOLBOX COMBO (A53843)
FUEL TANK/TOOLBOX...
2003 Ford F-550 4x4 Terex TL38P 38FT Bucket Truck (A51692)
2003 Ford F-550...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2012 Mazada 3 Sedan (A51694)
2012 Mazada 3...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
