Passivating stainless steel
   / Passivating stainless steel #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
I need to grind weld protrusions off 30 items that are "for sale" (60 grinds). I want to passivate just that one grind spot so it doesn't leak rust onto visible parts. The grind area is about 1/4" x 1/2", and it's on the underside so not visible.
Does anybody know an easy trick to get a small amount of phosphoric acid. I can order a whole quart of it but I don't want to store the remaining 99% of the quart, and I don't want to discard it either. I want just a little bit (and soon). Does anybody know of readily available products containing phosphoric acid?
Here's a pic of the grinded area, and it's been wire-wheel'd with a stainless brush. Thanks!
   / Passivating stainless steel #2
Not sure, but we used a solution of Nitric acid. Heard that it might possibly be done with citric acid.
   / Passivating stainless steel #4
Many soft drinks contain phosphoric acid. My mother told me stories of how her father would clean the rust off the plows on the farm with Coke... Or perhaps try a bottle of Naval Jelly? I've wondered about this item myself, so I will be watching for responses...
   / Passivating stainless steel #5
Why would it "leak rust"? Use a new grinding wheel and you should be fine.
   / Passivating stainless steel #7
Home Depot sells phosphoric acid ...
   / Passivating stainless steel #8
Here's a pretty good article on passivation:
How To Passivate Stainless Steel Parts : Modern Machine Shop
It recommends either nitric or citric acid (depending on the alloy), with no mention of phosphoric. Citric acid might be available at your local pharmacy.
While I can appreciate your desire to minimize the amount of chemical waste your passivation process generates, it seems like that should take second place to following whatever steps are necessary to produce the desired result. Time, Cost, Quality: Pick any two. In this case it seems like you want it fast and inexpensive (smaller quantity of acid), so you might not get the passivation needed to resist whatever corrosive environment the parts will see. But if you had the time to order the correct acid from an on line supplier, you may find it available in a small quantity at a more reasonable price than might be available locally (assuming the correct acid is even available locally).
Rock I could use a new grinding wheel but I'd like one that was rounded not a sharp square edge, I guess I could abuse it for awhile on stainless scrap. I'm not sure that is all it takes as stainless has subsurface iron I think. ?
"Plan B" is to just order the dang QUART of "pickling paste" and then decide what to do with it. Last time I had a small plastic "35mm film cannister" of it. I set it on a windowsill and it softened the paint below. I heat-sealed the cannister in 2 layers of 6mil plastic sheet and moved it to another windowsill where it sat forgotten a couple years, and it etched the nearby glass. I'm certain I can find a way to store this stuff, but for the moment I am avoiding having it around. I have all weekend to give "plan A" a chance.
I read the article and it was interesting, but didn't seem to align with my experience.
My experience is from one stainless steel welded deck railing that a friend made for me. All cutting was plasma-cut and some grinding. When it was new it was shiny. Over a couple months or so (outdoors) it turned darker, and rusty. I used pickling paste and it got pretty shiny, almost instantly. It started darkening again. My buddy said pickle it again. This time it got even shinier (almost instantly). The next day I pickled it again, this time it got real shiny, like stainless steel ought to be, and it's still shiny today.
Another time I wiped down a stainless steel item, (a motorcycle protection bar) that had "lost its shine" and looked like it was darkened by rust stain that wouldn't wipe of with any solvent. Wiped it with pickling paste and it looked instantly 'like new'".
That's about all I know about pickling paste. I guess plan C is to ask my buddy for some paste but he's a busy guy and I ought to first try to get some on my own.
I'm interested if there are readily available alternatives (Ospho, Naval Jelly?). I do NOT want to turn the iron black, I want it to remain bright stainless as in the pic. Hoping for those with experience to join in the discussion and I think others are interested too so thanks to all for posting.
   / Passivating stainless steel #10
My experience has been with 304L and 304ELC nuclear components in operating power plants, and they were given a nitric acid based passivation treatment after welding and grinding. I once won an all expense paid trip to a reactor in Vera Cruz, MX to supervise grinding out rust stains on the stainless steel cladding. It seems iron contaminated grinding wheels and wire brushes were used during fabrication, and rust formed in the salt laden air at the beaches above Vera Cruz. I got to watch as crews used NEW, never before used on anything else, abrasive flapper wheels and grinding discs to clean off the rust. Once removed, it didn't return even though we didn't bother with a passivation treatment. But if you want the shine, you need to establish the very thin layer of nickle and chrome oxide as referenced in the article, and nitric or citric acid is one way to do it.
I've never heard of pickling paste, but when I looked into it I found it contains both nitric and hydroflouric acid, not phosphoric. Hydroflouric is really nasty stuff, not just for your window sills, but for you as well. This article makes it pretty clear you need to be very careful when using it:
HSE - Welding: Post weld cleaning using pickling pastes - Information documents
This search turned up a couple of sources, but it isn't exactly cheap:
https://www.google.com/search?q=pickling+paste+stainless+steel&ie=utf-8&oe=utf-8
Seems like what you really need is a way to store it that won't damage the surroundings. If you bought a quart of it you may find that it is sold in a container that doesn't leak corrosive vapors, and next time you need some you'll have it. If you're successful in mooching another batch from your buddy, snag one of those small polypropylene screw top bottles from a backpacking store and put it in that. They're pretty inert and don't leak.
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
Countyline 15 Gallon ATV Sprayer (A44391)
Countyline 15...
Fleco 36" 13.5-15.5T Excavator Bucket (A42203)
Fleco 36"...
Year: 2015 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: 56,365 Plate: Body Type: 2 (A44571)
Year: 2015 Make...
2019 NRG BLENDER (A45333)
2019 NRG BLENDER...
New/Unused 40ft High Cube Shipping Container (A44391)
New/Unused 40ft...
