Parts look-up, 185 hydro PTO clutch
   / Parts look-up, 185 hydro PTO clutch
I got the Sunbelt aftermarket sub mentioned earlier. Link below - the Amazon vendor cancelled the order/couldn't get.
Sunbelt B1XT0409
The install was very easy and it appears the assembly was properly set up from the factory - the spring tension works fine.
I will say, this is the strongest the machine has mowed since we got it. So I would concur with an earlier comment that the clutch had been slipping for some time.
Now the wild card - how long will it last? I am tempted to order a spare, along with a set of belts, with all we mow out here - I have a lot of thick field brush to get through, yea not the right machine but our tractor is still down and thus no brush hog. So if I can get what we need mowed down and maintained with the lawn tractor for the time being we'll be OK. It appears we can - I did some test cutting last night and the lawn tractor will do it, just a couple passes and slow going.
   / Parts look-up, 185 hydro PTO clutch #12
:eek: That might be the worst one I've ever seen. Time for a new PTO clutch for sure.
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
