Parts look-up, 185 hydro PTO clutch
   / Parts look-up, 185 hydro PTO clutch #1
FlyFishn
IH 444 gas
All,
Is there an online parts look up that I might be able to search for parts on for a 185 hydro? I believe it is a 1987 model.
The electric PTO clutch is out. I've done some initial diagnostics and have narrowed it down to the clutch. I have not removed it, so it is conceivable there is a wiring issue from the connector back to the coil that I haven't discovered yet (I did not check the resistance/ohms of the connector on the clutch side, just voltage at the tractor end of the harness).
If it means anything SN is M00185B450271
If I can see the assembly down there in a diagram that will help before I proceed. It looks like the bearings are replaceable also - it might be advantageous to replace them, unless a new clutch comes with them (another reason a diagram/break down would help).
   / Parts look-up, 185 hydro PTO clutch #2
Thanks for the links.
It appears there are a few options for the clutches. Mine is closer to the ST552674. But its not available. Any ideas?
Looks like the assemby I need is AM123123.
There is a substitution from Sunbelt that appears to be a drop-in replacement. Any thoughts from anyone on this one? Way cheaper than the Deere.
   / Parts look-up, 185 hydro PTO clutch #5
Prolly worth a shot.
   / Parts look-up, 185 hydro PTO clutch #6
Before you throw money at it you should test a few things first.
Measure the resistance of the clutch coil while it is disconnected from the tractor. should be between 3.5 and 4 ohms.
Measure the voltage going to the clutch with the clutch disconnected and pto switch on. should be battery voltage.
Measure the clutch air gap. this is explained on page 40-05-1 of the service manual posted above.
If the air gap is to large the clutch will not work. magnetic force cannot overcome the large air gap.
hope this helps some.
Thanks for the notes.
A couple more tidbits - the clutch quit mid-cut. I mowed about 1.5 out of 2 acres and the blades shut off. I reset the PTO switch and the clutch engaged for about 10 more seconds, then quit and has never come back.
Of the checks mentioned - I have not checked resistance or air gap. However, since it was running fine, came back briefly, then died for good - Id say the air gap is fine.
The issue is more than likely electrical. The question is where - wire or part of the coil itself?
When I get a chance to be home with some time to do so I will dig in to it deeper. In the mean time I have a new/aftermarket unit coming. Better to have on the way and possibly stick in a shelf to have on hand for later than to need it now and not have it.
   / Parts look-up, 185 hydro PTO clutch #8
I had my Jd do the same thing I adjusted the air gap and it works fine
Windings desintegrated. Id say its toast and Ill need the new assembly.
   / Parts look-up, 185 hydro PTO clutch #10
That clutch is toast. It looks like it might have been slipping for awhile and ground away the friction disc.
2013 John Deere 8360R MFWD Tractor (A53342)
2013 John Deere...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
