Parts for Iseki
   / Parts for Iseki #1
FoodPlotsMan
Have an Iseki tracktor (3 cyl diesel) and think my motor is toast. Making a loud noise (metal to metal) after it slowly died. Have a local dealer who is willing to do the labor on the fix or rebuild, but he wants to know where he can order parts of he needs to do so. What's the best source for engine parts on this thing? Thanks! Chris.
   / Parts for Iseki
Thanks. I need to get back out to the farm to see what engine it is specifically and I'll look at my owners manual, but I do know it is a 3 cyl. diesel. Stay tuned. Thanks too for the other website info! Chris.
   / Parts for Iseki
OK, went to the farm and read the tag on the side of the engine. It reads
Diesel Kiki
Has the following numbers in this order:
104303-2040
3KG930557
NP PE 63K600410RS(N?) 14
515601-0142
G0V(11?) PT (This it was talking about the governer)
425-1300 RPM
Can anyone tell by this, what specific motor it is and where parts might be found? Thanks! Chris.
   / Parts for Iseki #7
It should have some numbers cast in the side of the block ie.. E3AD1, E3CC etc.
   / Parts for Iseki
Went to farm this weekend and found the numbers on the engine block above the filters. They read:
3AE1
1-296L
80221
Also, found a plate on the block on the alternator side that reads:
TL2300
1.296L
23PS/2600 r.p.m.
Any extra help for parts is appreciated. Thanks! Chris
   / Parts for Iseki
Bruce: That's great, would you sell it whole or if my repair shop only needs parts from it would you sell those. Is their a lot of hours on it? Thanks. Chris.
   / Parts for Iseki #12
Hello
Looking for a crank or short block for 3 cyl diesel Iseki engine for my Massy GC2300. Crank split at the journal counter weight. Thanks
   / Parts for Iseki #13
pjw said:
Hello
I think I have one
   / Parts for Iseki #14
Hello. Got a MF 1250 with the EC3D. It lightly spun the #2 rod journal and scuffed the main bearings. I found a rod on ebay, ($75) as well as a crank ($1,000!!) but I'd much rather have this crank turned. Anyone know where to get bearings for this little oddball? Hours of web searching has yielded little. The bearings are NDC STD 8Y8J for the rods and the mains are NDC STD 8Y8K. No luck searching those other. A blind engine code search yielded a few .pdf's like this one with the same engine.
ftp://62.2.165.60/Iseki/Traktoren -...ts list/TG5395-5475 1747-095-1000-A ET-GB.Pdf
On page 34 of that link the mains and rods are called out, but those searches revealed nothing. On page 58 undersize bearings are listed but again, nothing serchable.
Has anyone successfully rebuilt one?
   / Parts for Iseki #15
Chris,
I have a spare engine components fo the ISEKI E3CD 3Cylinder (Fresh block, crank pistons & rods, bearings (Can't tell from new), front cover & pan & oil pump.
Raymond,
612-743-1770 or omega1direct@gmail.com
   / Parts for Iseki #16
Raymond,
CASE DX18E TRACTOR (A60430)
CASE DX18E TRACTOR...
(1) 48"X8' ADS DRAINAGE PIPE (A60432)
(1) 48"X8' ADS...
2012 VOLVO A30F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A30F...
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
2020 CAT 308 (A53317)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
